Sponsored by: Real Truck
Tires Cupping Or Scalloping
Old Aug 16, 2005 | 04:45 PM
jorzac's Avatar
jorzac
Noticed all 4 tires on my 2004 6.0 CC 4x4 are cupping or some call scalloping. The truck has just over 12,000miles on it and the tires have not been rotated. Running recommended air pressures as spec. on inside drivers door tag. Any ideas why? This truck has not seen any off road conditions or anything else that would affect the alignment.
Old Aug 16, 2005 | 06:44 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Thread moved - member notified
Old Aug 16, 2005 | 06:53 PM
captchas's Avatar
captchas
Guest
tire on a 4x4 or any vehicle today need to have the tires rotated every 5k at max. check out your owners manaul it states every 5k on a super duty
Old Aug 16, 2005 | 09:24 PM
wiingnut's Avatar
wiingnut
I swear by it!
Old Aug 16, 2005 | 09:51 PM
BareBones's Avatar
BareBones
Okay, I'll bite. I thought cupping was essentially due to weak shock absorbers permitting the tire to bounce. How does rotating the tires help? Do they get out of balance maybe outboard or inboard. Even if they did why would this cause cupping as opposed to tread wear?
Can any expert tire readers help?
Old Aug 17, 2005 | 06:39 AM
floorshow's Avatar
floorshow
Could be over inflation.
Old Aug 17, 2005 | 07:36 AM
BFR250SD's Avatar
BFR250SD
I'd start by getting them balanced and road force variation measured by a good tire shop. I had this problem with my MTR's and that's what it turned out to be. Also have them check the rims for being out of round or excessive runout. You may want to get the tires checked for being out of round as well. I doubt this being stock tires though.
My second course of action would be to get an alignment, if necessary. Just because you haven't beaten on it, doesn't mean it was perfect from the factory. Also have them check all the steering, suspension, and driveline components. I would have the dealership do this in case their is something that can be warrantied.
Lastly, would be the shocks. The above conditions would render even the best shocks useless.
Hope that helps a little.
Old Aug 17, 2005 | 09:21 AM
F3504ME's Avatar
F3504ME
I purchased a 2003 F250 CC 4x4 PSD with 21K miles on it...
The fronts had the same wear....really odd cupping /feathering....pulled to the right as well...pretty unpleasant....
Took it to a tire shop and the owner took one look at the tires and said lack of rotation ie,never been... He said these trucks need their tires rotated min...5K miles....
They rotated them and all better.....no pull...tracks straight.....
The all 4 part is pretty unusual though
Chris..
Old Aug 17, 2005 | 09:26 AM
Big Orn's Avatar
Big Orn
All four tires, jorzac? Are they cupping with the same pattern or are the rears wearing different? Could be bad factory tires...
But, rotation is the best medicine, regardless.
Old Aug 17, 2005 | 10:24 AM
jorzac's Avatar
jorzac
Big Orn---Yes all 4 tires are cupping with similar wear patterns. However, the fronts may be just a little worse. The reason I did not rotate them was I noticed some abnormal wear on the fronts at about 6000 to 7000 miles. I figured I could isolate the cause this way.
stkelly
Jul 18, 2011 04:40 PM
kupiec20
17
Jan 18, 2011 10:44 AM
haulingboat
Apr 14, 2008 07:14 PM
digger19
1983 - 2012 Ranger & B-Series
Nov 18, 2006 03:45 AM
huckster
Jul 29, 2003 06:01 AM
