going to start looking for some wheels
Old Aug 16, 2005 | 11:37 AM
iceman320's Avatar
iceman320
hey guys it's been a while. any way I want to start looking for some nice chrome or polished wheels for my 78 f-150 and I wanted to know what lug pattern and back spacing do i need to get for the wheels to fit right. thanks in advance.
Old Aug 16, 2005 | 11:56 AM
77300i6's Avatar
77300i6
5 Bolt : 5x5.5"
Backspacing: 3.5"-4" I think
Old Aug 16, 2005 | 01:49 PM
MBBFord's Avatar
MBBFord
I was told it was 5x5 for a 2wd and 5x5.5 for a 4wd.
Whitch seems to be right, because I tryed to swap wheels and tires off my 79 4wd Bronco and put them on my 77 2wd F-100 and they would fit.
Old Aug 16, 2005 | 02:19 PM
77300i6's Avatar
77300i6
Smile MBB Ford...
Maybe Oldhalftons could step in here and clear this up. That's the first I heard of that, but you may be right here.
Old Aug 16, 2005 | 02:20 PM
77fordguy's Avatar
77fordguy
my 77 f150 2wd is 5x5.5
I need wheels also, but I may just paint the stock ones to match the rest of the truck when I paint it.
Old Aug 16, 2005 | 03:22 PM
iceman320's Avatar
iceman320
ok thanks for the help guys if any of you guys find out for sure what bolt pattern and back spacing i need please post. my 78 is a 2wd f- 150. thanks
Old Aug 16, 2005 | 03:32 PM
Rock.well's Avatar
Rock.well
I had a 77 and now have a 64 and both were 5 by 5.5. I am sure that is what you have on yours unless there has been some mods.
Paul
Old Aug 16, 2005 | 03:44 PM
MBBFord's Avatar
MBBFord
That's what I alway heard, was the bolt pattern was 5x5.5, but I can't fit my wheel off of my Bronco to my F-100.
Both are stock and I thought they would switch right over, but didn't, I'm going try again, because I really want to switch tires.
Old Aug 16, 2005 | 07:28 PM
JoeBlow's Avatar
JoeBlow
My door tag says 5 X 5.5. 1979 F100
Old Aug 16, 2005 | 07:45 PM
hotroddually's Avatar
hotroddually
i have a set of factory aluminum wheels off a 79 bronco and i put them on my 79 f100 2wd ,they fit no problem. the same wheels spent some time on a 76 econoline van we had also. i used to have 78 bronco steel rally wheels (factory) on my 72 f100 2wd.idont see how they wont fit your ride mbbford? they should bolt on.-billy
Old Aug 16, 2005 | 09:20 PM
LxMan1's Avatar
LxMan1
All 5 lug are 5x5.5" until 97 when they changed to 5x135mm.
Old Aug 16, 2005 | 10:19 PM
MBBFord's Avatar
MBBFord
I always thought they were 5x5.5 and I tryed to swap tires from 4wd to 2wd and they didn't fit. I retryed today and they fit, so now I don't have to be mad about them not fitting, whitch is good news.
Old Aug 22, 2005 | 11:24 AM
iceman320's Avatar
iceman320
ok thanks for the help guys now what back spacing would I need on the wheels. thanks
Old Aug 22, 2005 | 01:21 PM
iceman7329's Avatar
iceman7329
LxMan1 is correct, they are 5 on 5.5 2X4 or 4X4 doesnt matter.
Old Aug 22, 2005 | 02:46 PM
iceman320's Avatar
iceman320
what backspacing do I need to get so that the wheels will clear the brake calipers on the front? and what backspacing would look good will 10" wide wheels and tires in the rear? thanks
