my actron code scanner gave code 653 transmission control switch did not switch during key on engine running self test .my truck will run fine during highway cruising speeds, tthen suddenly loses all torque. engine revs and if i dont get foot off accelerator it slams back into gear.problem is becoming more frequent.
i cant find switch on internet.
where can i find switch?
what else could be problem?
can i do repair myself?(novice)
also getting codes853 and 663 which are not listed in actron book.
i am wary of transmission shops.
please help its an otherwise fine truck and almost paid for!
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
