Power brakes/conversion
Old Aug 17, 2005 | 01:50 PM
staysbroken's Avatar
staysbroken
If that were the case though, wouldn't brake pressure gradually decrease when I hold the pedal down?
Old Aug 25, 2005 | 10:07 PM
1975Ford's Avatar
1975Ford
No, the leak could be internally within the master cylinder pistons.
Old Aug 25, 2005 | 11:39 PM
Mil1ion's Avatar
Mil1ion
Yes it would as the fluid doesn't go anywhere except by-passing the rubber piston seals allowing the pedal to drop.
This is known as a bad M/C .
There are a few brake re-build companies that install a stainless steel sleeve.
This replaces the cast iron machined area for the piston & seals ,that often causes a bad M/C.
I think EIS is one of those companies.
Maybe do a google of Master cylinder with stainless steel sleeves & read what comes up ?
Then replace the one you have with the newer construction.
Old Aug 27, 2005 | 10:42 AM
staysbroken
Well I'm almost sure now that the problem was the incorrect pedal. At the junkyard, I didn't see any '73-'79s with power brakes, but I did see several newer models with power and manual. I snagged the pedal off an '81 just to compare it to mine. On my pedal, the master cylinder pushrod connects about 3/4" below the pivot point. On the '81 with power brakes, it connects about 3" below the pivot. I think I'll need a whole pedal assembly though, since the mounting point will have to be roughly 2 1/2" higher in order for the pin to line up with the master cylinder pushrod.
Old Aug 28, 2005 | 10:21 PM
1975Ford's Avatar
1975Ford
Just wondering if you could just drill a new hole at the correct height on the brake pedal.
Old Aug 28, 2005 | 10:26 PM
1975Ford's Avatar
1975Ford
I have a 76 and a 78 Ford with power brakes, I can measure the distance from the pivot point on the brake pedal to the push rod pivot.
Old Aug 29, 2005 | 01:41 PM
staysbroken
I think the previous owner thought of that and tried it... Looks like he drilled a hole through the pedal about an inch down. The problem is though, the master cyl pushrod would have to come through the firewall that much lower in order for it to line up with the new hole. I may try cutting a new hole in the firewall and moving the master cylinder down and see if that works...
Old Aug 29, 2005 | 09:39 PM
Mil1ion's Avatar
Mil1ion
Stays, You never mentioned what year this truck is..It makes a difference
Old Aug 30, 2005 | 05:06 AM
staysbroken
Sorry, it's a 78
Old Aug 30, 2005 | 01:59 PM
73FOMO's Avatar
73FOMO
Need Help with my conversion as well!
I've got a 73 2wd with manual brakes and want to upgrade to power. How hard is this? And what parts do I need to round up? Anyone else out there pulled this off with success?
big-papa
15
Oct 18, 2010 08:34 AM
richardd
Aug 21, 2008 10:14 AM
staysbroken
Aug 15, 2005 06:48 PM
dickboyd69
Aug 14, 2001 07:49 PM
552884960
May 25, 2001 02:02 PM
