1992 Ranger floppy side mirrors
Old Aug 15, 2005 | 02:52 PM
Steve Ingalls's Avatar
Steve Ingalls
I have a 1992 Ranger, 219k miles, still working well. I would like to keep it on the road a while longer while saving for another Ranger.
Both side mirrors flop inward at speeds over 50 mph. Naturally, there is no tensioning screw adjustment as there was on my father's Oldsmobiles.
My questions are:
Does anyone have a clever way to fix these mirrors?
If not, I can find replacements, but that raises another question. If I unscrew the mirrors from the doors, will whatever the screws screw into behind the door panel stay in place, or does it fall away necessitating door disassembly?
I know that these are lame questions, but there is a great deal of useful knowledge in this forum, and maybe someone knows.
Thanks in advance.
Old Aug 15, 2005 | 07:13 PM
e g rred's Avatar
e g rred
You can unscrew the bolts that hold the mirror on without the inside nut falling to the inside. I tried mirrors from j c whitney but they wounld not match the hole pattern so you may have to go to the dealer . Keep us updated
Old Aug 15, 2005 | 07:26 PM
DetailerDave's Avatar
DetailerDave
I had the same issue with 90 paddle style mirrors. Got one at the dealer. Too much $$$. Pass side started doing same thing. Got one from eBay. You can get a pair, new for less than one from the dealer. Mine is fine, and no complaints. Just save the original screws, as the new one (eBay) came with sheet metal screws, I believe.
Oh- the screws go into captive-nuts in the doors.
Try this ebay #: 7992743110
Old Aug 15, 2005 | 08:24 PM
Hank85713's Avatar
Hank85713
on my 94 you pull the bottom plate off and there is a tork bolt up there. I found that the mirror housing wears and nothing in reality can be done to tighten them. I got some of that 2 part plastic mender and gooped them both up and they are staying in place. do it on a weekend when you dont plan to drive, 24 hrs to fully cure. if ya get neat you can then paint the mess as it will turn yellow on ya.
Old Aug 15, 2005 | 10:12 PM
rebturtle's Avatar
rebturtle
Your neighborhood automotive store should stock "OE Style" direct replacement mirrors. They are an almost exact replica, except that they do have tensioner nuts! I'm pretty sure they go for about $12 each (make sure you get 1 left and 1 right - they are different).
NakedCreekML
May 3, 2017 06:50 PM
FireFerret
1997 - 2003 F150
Jun 30, 2014 11:39 PM
robert_l_ross
Nov 1, 2011 06:34 PM
DarrellJ
Dec 27, 2009 10:54 PM
kramge
2004 - 2008 F150
Jul 21, 2006 06:13 PM
