Fender??
Old Aug 15, 2005 | 02:26 PM
1992flareside's Avatar
1992flareside
Fender??
Does anybody have or know where I can get a diagram of the fender showing all the bolts to take off the drivers side fender??
Old Aug 15, 2005 | 05:36 PM
Beast12's Avatar
Beast12
Thread moved to 87-96 F-150 forum.
-Matt
Old Aug 17, 2005 | 08:34 AM
1992flareside
There is nobody here that can tell me how to take offthe drivers fender,diagram?,or just tell me where the bolts are on the front side of the fender. do I have to take off the headlight assembly?
Old Aug 17, 2005 | 10:12 AM
quicklook2's Avatar
quicklook2
looked in manual for you, pic shows pass. side but give a description for both sides. here is what it says to do for driver side fender removal:
-remove headlamp
-remove screws attaching fender to radiator support
-remove one screw attaching lower end of fender to cab
-remove one screw from inside attaching lower end of fender to cowl
-remove screws attaching front fender to cowl extension
-remove screws attaching fender to apron
-remove hood latch from left fender
-remove hood assist spring to front fender
-remove fender
hope that helps. you may need to do some misc. unhooking so good luck.
poco
Aug 25, 2012 08:16 PM
Austin26372
Feb 20, 2011 03:31 PM
arrowheadfred
Dec 14, 2010 05:59 PM
mickelsons
Mar 23, 2002 10:22 PM
dspa23
Jul 17, 2001 12:04 PM
