'95 5.0 Oil Pan replacement
I've read all of the great tips on replacing the oil pan in the truck. It looks like all '87-'95's will require the upper plenum to be removed, no problem. One small item that I see no mention of. Do you use any sealer/RTV/Right Stuff anywhere when using the one piece style pan gasket?
Thanks,
Thanks,
Heck, I glued the whole gasket down to the pan, just to make it easier when I put it back together. I didn't want that gasket moving all over the place. I still ended up having to take all the bolts back out and reset the gasket behind the harmonic balancer as it got pushed in at the bottom of the cut-out there (it was getting dark and starting to rain...grrr).
Jason
Jason
