A4Ld Leaking like a sieve......
So I decide to drop that sucker and put in new seals! Ha!! Fun stuff if I do say so myself. Getting the trans out was not so bad. Raised the vehicle up on jackstands, removed the driveshaft, no big deal. Drained fluid, again, piece of cake. Only 2 complaints I had was the access hole to torque converter to crank plate was way too small, and access to cooling lines was damn near impossible to get too. Other than that not too bad to get out.
I then cleaned that sucker to look brand new. Replaced the front seal and the rear seal. Replaced the Pump seals and installed new pump gasket. I know I should have rebuilt with new internal parts but it was shifting without any problems so I left well enough alone. We will see down the road I'm sure.
Anyways, my son helped me get it back in and all lined up. Of course after all of the heavy muscle work, it was almost "beer:30" so we took our time tieing up the loose ends.
Long story short, no leaks, shifting as good as before, and I hopefully saved better than a "grand" again!!
I just needed to tell others who would understand what was accomplished!
Oh yeah, on the Sam Adams scale, definitely a "10 Sammy" job.
-reever
you did what you had to do to get the Aero back on the road and Joe Smuck at the local "Ripoff Tranny Shop" doesn't have $500 for a $200 job.
definitely a 20 Sammy job laying in a pool to soak the back pain.
one "trick" with really difficult transmission cooling lines is to cut them where they are accessible with hacksaw, clean out cutting well from inside of lines, then jumper with neoprene hose and clamps when reinstalled. or cut a 3" diameter hole in floor pan with hole saw for access. replace with larger piece of sheet metal, sealer and screws.
some of the lines in certain models are put on prior to tranny/engine install into chassis in factory. impossible to get at fittings in vehicle. why? cheap is better.
how many miles on present tranny?
Once under the van, I couldn't get the tranny lifted high enough to get the jack under it. So I used a wheel ramp and me and the son (you know the type, no neck and one eyebrow) pushed that sucker up onto where your wheel would sit! Worked great!
Once there, it took about 2 hours of gruntwork to get it lined up properly.
This is the original trans, vehicle has about 130K on it.
The one trans shop I did talk to wanted $400 just to drop it! He really didn't like to do Aerostars. Of course, the price takes off from there once it's out of the van....
-reever
a real auto repair shop.
Local independent shop here quoted me $660 to change 2 spark plugs-I had done the others and didn't have tools at time to reach the 2 and change the auto tranny, front and rear diffs oil, transfer case fluid. I bought the tools, Mac, synthetic tranny fluid and diff oil and filter, still had $550 of my dollars left in my pocket.
Local Ferd dealer charged me $280 for check engine light and PCM reprog when 1 year old on warranty, I fought with Ford regional service rep until blue in face and state attorney general's office. Nada. Needed van at time so paid up.
They did replace windshield and the two large side windows, factory warped and leaked like a sieve-new, no charge to me warranty, wonder what they soaked Ford Motor for that , $2000?
Have not been back since and will not buy a Ferd there.
Only one thing that makes me sicker than dealing with a car salesman is dealing with an auto service manager. They act like they are doing me a favor by fixing their warranty junk.
Have been doing all my own work now on it for last 6 years.
This board is great with suggestions, recommended parts and tips specific to Aero.
Enough soapbox, worktime in saltmine.
-reever
Because Ford does not pay what the repair actually takes to do by normal people (www.flatratetech.com). Then again, only a short sighted jerk would treat a warranty customer badly. I always looked at HAPPY warranty customers as good potential cash customers and as new and used car buyers.
