Transmission swap
Old Aug 14, 2005 | 05:55 AM
lmhans4440's Avatar
lmhans4440
Transmission swap
I was wondering about a transmission swap in a 2 wd 1978 F-150 w/300 ci. The truck has a clark overdrive, and I am looking to put a t-18, t-19, or a np 435 in it. Is the bell housing interchangable? What about driveshaft length? Clutch linkage? Has anyone done this before?
Old Aug 14, 2005 | 11:23 AM
oldhalftons's Avatar
oldhalftons
clutch linkage is based on engine and bellhousing, so you won't need to change it.
all 3 of the transmissions you mentioned will bolt to your bellhousing
2wd t-18's, t-19's, 435's all use a bolt on yoke so you will need a two piece driveshaft.
You'll need to cut the floorpan insert.
Old Aug 14, 2005 | 02:46 PM
lmhans4440's Avatar
lmhans4440
oldhalftons, what about the clutch?
Old Aug 14, 2005 | 06:21 PM
oldhalftons
they are all 1-1/16" 10spline
MavSprint
Ford Truck Parts for Sale
Mar 8, 2017 07:09 PM
Kelly Burleson
Dec 18, 2014 09:13 AM
family xj
Dec 4, 2012 07:52 PM
1975MudRat
May 15, 2012 06:41 PM
germanford390custom
Oct 14, 2009 01:56 PM
