transmission swap
Old Dec 17, 2014 | 03:36 PM
Kelly Burleson's Avatar
Kelly Burleson
transmission swap
I'm a new member. I have an 85 F150 with a 302 5.0. It has an aod transmission. The linkage is broken and the tail shaft is messed up. Is there another transmission that can just be swapped into the truck as is or is the aod the only transmission that will work?
Old Dec 17, 2014 | 03:55 PM
Gary Lewis's Avatar
Gary Lewis
A C6 will bolt up to the engine, but I don't know if it is the same length. If it is much different in length the drive shaft may not work.
And, by the way, welcome to FTE!
Old Dec 18, 2014 | 08:57 AM
Kelly Burleson
Thanks Gary. Since the aod is a four speed, and the c-6 is a three speed, how would I change the gear selector?
Old Dec 18, 2014 | 09:13 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You wouldn't change the gear selector. Both the AOD and the C6 use the same number of positions.
Rusty_S
27
Mar 12, 2019 10:30 PM
fattmann
Apr 25, 2007 03:33 PM
fattmann
Feb 1, 2007 02:08 PM
Katmandu2
Aug 29, 2003 01:11 PM
felixbot
Sep 25, 2002 11:07 AM
