What causes Deiseling?
Old Aug 13, 2005 | 11:33 PM
460_Sprout's Avatar
460_Sprout
when I drive the truck for a while and shut her off she sputters and keeps runing, I believe this is called deiseling correct? What woudl cause that? The carb was recently rebuilt, but I believe my choke is not working properly I need to buy a new electric choke. I have a Holley 4160 on a 460 engine.
Old Aug 13, 2005 | 11:34 PM
ford390gashog's Avatar
ford390gashog
i have seen some engines diesel and start to run backwards while dieseling but i am not sure what causes it.
Old Aug 13, 2005 | 11:54 PM
LxMan1's Avatar
LxMan1
It is caused by high cylinder temps with carbon build up. The carbon heats up red hot and when you kill the ignition, the glowing carbon acts like a glow plug and continues to fire the fuel in the cylinders.
Common causes of this are a lean condition which elevates cylinder temps, too fast of an idle, and heavy carbon build-up in the combustion chamber. Any of these conditions combined with low octane fuel will cause it to diesel (IE: run without a spark plug)
Old Aug 13, 2005 | 11:56 PM
460_Sprout's Avatar
460_Sprout
ok, my idle is high, its set at about 1300 rpm in park and idles around 900 in gear, I need to adjust it, but the choke is in need of replacement so this si the best way to keep her running right now, I'll try and lower the idle but she doesn't like to run if I do, we'll see what happens.
Old Aug 14, 2005 | 12:30 AM
LxMan1's Avatar
LxMan1
As long as the choke is open, you will be ok. It may take a minute to keep it running when cold. Your mixture screws may need adjusted out some if it doesn't want to idle about 650 to 700 in gear.
DynamoDale
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Feb 29, 2012 11:00 PM
sparky1166
6.7L Power Stroke Diesel
Dec 6, 2010 02:00 PM
bdcrecy
General Diesel Discussion
148
Nov 13, 2007 04:45 PM
deisele75
Dec 24, 2006 06:32 PM
62BigBlue
19
Aug 7, 2003 06:21 PM
