blown power valve
Old Aug 8, 2005 | 09:29 PM
oldfordtrucksrule's Avatar
oldfordtrucksrule
blown power valve
always heard older holleys will get their power valve blown out with a backfire through the carb, does this usually happen with stock ford carbs too?and if so is their a mod to fix this like the newer holleys got the check valve or whatever in em to keep backfire pressure out of the valve.
Old Aug 8, 2005 | 10:16 PM
LxMan1's Avatar
LxMan1
I haven't heard of this with Stock Ford carbs. They usually just dry rot.
Old Aug 13, 2005 | 11:07 PM
Netfly's Avatar
Netfly
Had that happen to a Holley 4180 in a ford bronco. I Installed a "Power Valve Saver" and replacement power valve from summitracing.com. Never happened again. The mod is easy and worth doing but you have to remove the carb to drill it from the bottom.
Old Aug 14, 2005 | 04:25 AM
fmc400's Avatar
fmc400
MSEE
I've heard it's possible at least on the stock 2 barrels, but I've never had it happen personally. I've had some terrible, terribe intake backfires on a 400 and it never blew a single power valve.
Buyerz
Jul 11, 2016 12:37 PM
Goose_52
16
Dec 20, 2011 08:14 PM
70_f100
Mar 20, 2006 12:03 AM
bspeedy
Jun 29, 2004 07:47 PM
DailyDriver
Jul 21, 2002 12:14 PM
