Need Help Asap
Old Aug 13, 2005 | 09:25 PM
J&JProperty's Avatar
J&JProperty
Need Help Asap
Here's my problem:
While driving today the check engine light cam eon and I lost 75+% of power.
99 F250 PSD only mods are filter and 4" exhausut turbo back.
I'm thinking CPS or ICS but I would hat to dump money on the wrong sensor and I need my truck. I have check the harness into (did not pull valve covers) the vavle covers. Had fuel when I opened the seperator. I need this on the road tomorrow. Please help.
Old Aug 13, 2005 | 09:27 PM
HeatStroked's Avatar
HeatStroked
CPS is the first and cheapest attempt to fix if you don't have scanner to diagnose.
Old Aug 13, 2005 | 09:28 PM
tjbeggs's Avatar
tjbeggs
if the check engine light is on you need to get the code number to begin finding the problem. usually cam sensor is a run no run not lose power thing. go to autozone and have them pull the code for you.
Old Aug 14, 2005 | 07:14 AM
believer45's Avatar
believer45
When this happened to my 95 it was one of the wiring harnesses that runs from the valve cover gasket plug to the injectors / glow plugs on the right bank of cylinders. If you remove the oil cap and smell you can usually tell for that side of the engine anyway - you will smell an electrical/burned rubber smell along with the oil.
Dave / Believer45
