need help (wiring problems)please read
Old Apr 18, 2002 | 01:44 AM
Jermafenser's Avatar
Jermafenser
Old Aug 25, 2002 | 05:36 PM
TDOG's Avatar
TDOG
I have a 1977 F250 it has a 460 auto tranny. the other day all the sudden when I go to turn my rig over the starter starts to crank and stays cranking when the key is in the accessories position. The starter wire is staying hot I cut the wire behind the key switch and it was still hot on the relay side (not on the switch side). I've replaced the relay, regulator, and alternator nothing has seemed to work.my rig is only charging at 12.26 but the alternator when tested at the store was charging at 14. my neutral switch has been tampered with (not there). starts in any gear.someone suggested this to be the problem. any suggestions would be appreciated.
Old Aug 25, 2002 | 06:23 PM
Mil1ion's Avatar
Mil1ion
Whenever you get power to the starter solenoid with the ignition key in any other position than the start position,the problem is the IGNITION SWITCH.
http://www.clubfte.com/users/mil1ion/2cents.gif
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
64 1/2 Mustang Pre-World's Fair Car #8092
68-Mustang 289 2v-Sunlit Gold
[/font]
Old Aug 26, 2002 | 10:14 AM
beartracks's Avatar
beartracks
I believe the ign. terminal will back feed from the other small terminal in the run position. The second small terminal feeds a full twelve volts to the coil during cranking. In run the coil back feeds about 8 volts. If you have the ign terminal disconnected and it still cranks you have a welded solenoid.
Old Aug 26, 2002 | 10:41 AM
TDOG's Avatar
TDOG
Mil1ion, I have also replaced the ignition switch forgot to add it to my original post.
Old Aug 26, 2002 | 10:57 AM
Mil1ion's Avatar
Mil1ion
Beartracks is correct with his info too.
It really is a process of elimination to determine the cause of things like this.
[/font]
[/font]
Old Oct 6, 2002 | 05:30 PM
TDOG's Avatar
TDOG
old post, I broke down and took my truck to the shop. all my electrical problem was the orange and the white wires were switched on the back of the alternator causing the electrical system to back feed. The previous owners mistake
