Mercon SP
Old Aug 13, 2005 | 03:29 PM
Motown Fire's Avatar
Motown Fire
Question Mercon SP
Were is everyone getting there Mercon SP transmission fluid??? It's time to change the trans fluid so I need to find were to buy. Also were do you get the internal filter??? Thanks for the info.
Old Aug 13, 2005 | 03:50 PM
captchas's Avatar
captchas
Guest
right now the oil is ford only from what i have found. the filters some of our sponsers have them at great prices.
Old Aug 13, 2005 | 04:15 PM
toddyw's Avatar
toddyw
Motown, The internal filter is really just a wire mesh strainer, however ther is an external filter on the passenger side of the radiator, at the bottom. It is the canister type is is a booger to remove, but it will come off.
Old Aug 13, 2005 | 08:25 PM
Motown Fire
"The external filter--mounted on the cooler lines near the radiator--needs to be replaced at the service. Ford has no service interval for the internal pickup filter. I think it is a good idea to replace the internal filter at the service intervals as cheap insurance against a failure. There is a second transmission filter screen that is part of the valve body gasket, but it does not need to be replaced unless the transmission is being repaired."
This is from the diesel man website. I guess I need to find a service manual for this truck.
Old Aug 15, 2005 | 10:08 PM
3/4ER's Avatar
3/4ER
Just did my tranny PM, took 10.5 qts. I paid $3.85 per, and about $10 for the external filter. I dropped the pan, and removed the internal filter for inspection, everything was as clean as a whistle. I think you need a 28mm socket for the external filter, it's stamped on the bottom of the filter housing.
cj50
Mar 6, 2017 06:15 PM
superduty1967
Jul 9, 2014 06:26 AM
04scurs
Apr 5, 2013 09:19 PM
Primetime1
Mar 4, 2009 06:47 PM
60RatRod
Dec 6, 2008 06:15 PM
