1995 7.3 No start condition
Old Aug 13, 2005 | 09:04 AM
blueoval6079's Avatar
blueoval6079
I wanted to see if some of knowledgeable guys could help me out. I have read a lot of the posts, but cannot crank my 1995 F 350 w/ 7.3 engine. It has run fine for 124,000 miles, but left me stranded an hour away from home yesterday. It will crank on ether, but has no fuel pressure on the schrader valve. The fuel filter bowl is full of fuel. We installed an electric fuel pump just ahead of the front to rear tank switch on the frame rail. It made no difference. All the fuses are good and everything is full of oil. We tryed unplugging the Injector pressure control, but that did not help. I had to pay a 200.00 tow bill and am trying to get it fixed without spending a lot of money throwing parts at it. I have the Ford powertrain diagnostic manual, but no code reader to use withit. Any help would be gretly appreciated.
Old Aug 13, 2005 | 09:20 AM
clux's Avatar
clux
A little more information might help us diagnose the problem. What were the symptoms when it quit on you?
Does the Tachometer register rpm's when you crank with the starter?
When you say won't crank, do you mean the starter won't turn it over at all, or do you mean it won't fire?
By the way, ether can be really bad for your engine, and dangerous if you have your head under the hood when the ether in the intake ignites.
Old Aug 13, 2005 | 09:29 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome blueoval6079, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 13, 2005 | 09:38 AM
Budkole's Avatar
Budkole
try the CPS sensor, thats usually thr problem 9 times out of 10.
Old Aug 13, 2005 | 11:39 AM
blueoval6079
I guess we will start with the CPS sensor. I see no real RPM on the tach when cranking over, even though it the needle may move slightly.
Old Aug 13, 2005 | 11:46 AM
cookie88's Avatar
cookie88
FTE Emeritus
If the tach. needle bounces, it's getting a cam signal. Check for a blown fuse, your fuel heater may have fried, and if it did the resultng blown fuse will not allow power to the PCM.
Old Aug 13, 2005 | 11:56 AM
blueoval6079
Tach needle does not really bounce. Very slight if any movement. All fuses are good. Is the CPS located at the crank pulley?
Old Aug 13, 2005 | 12:09 PM
Budkole's Avatar
Budkole
Do you have a good place to get it? a cps, cause if you dont, i have an intn'l dealer about 10 blocks away from me and they usually charge about $103 with taxes
Old Aug 13, 2005 | 12:11 PM
blueoval6079
I am on the phoneith the dealer now.
Old Aug 13, 2005 | 12:13 PM
blueoval6079
149.00 with my discount
Old Aug 13, 2005 | 02:10 PM
blueoval6079
CPS fixed it right up. Big Blue is back on the road. Thanks for all your help.
Old Aug 15, 2005 | 02:33 AM
fedextech's Avatar
fedextech
blue, the lesson here is...don't leave home without a spare CPS and the tools to change it !!
Old Aug 15, 2005 | 09:09 AM
Budkole's Avatar
Budkole
Good to hear
acschex
Mar 18, 2013 11:41 AM
Anthony_martin650
23
Jul 1, 2011 10:00 PM
mercedes4oil
16
Feb 25, 2011 11:51 PM
Sundance Xpress
Jun 2, 2008 08:02 AM
