No Start..... HELP
Old Mar 11, 2013 | 12:18 PM
acschex's Avatar
acschex
No Start..... HELP
OK, I have a 1995 with a 7.3. I have an issue of a no start. The truck will start on ether. We have checked the high pressure pump pressure, it is ok. We did an injector buzz test, they all buzzed. We have tried and IDM, and also a PCM. We have also checked the mechanical fuel pump pressure and that is ok also. Any help will be greatly appreciated! Thank you!
Old Mar 11, 2013 | 12:42 PM
madpogue's Avatar
madpogue
What temperature is it where you are? Have you tested your glow plug system?
Ether is a Bad Thing with modern diesels, esp. with the glow plugs. The fact that the ether did not ignite on the glow plugs, blowing up the intake, suggests that your glow plugs may be inop.
Old Mar 11, 2013 | 01:05 PM
fordpride's Avatar
fordpride
After the truck is up to temp does it still need ether to start?
Have you check batteries and starter ?
The truck need to spin over pretty good for them to start.
Old Mar 11, 2013 | 01:06 PM
acschex's Avatar
acschex
Ether is starting fluid, when you know how to use it correctly, you will not ruin anything.... we know how to use it..
Old Mar 11, 2013 | 01:08 PM
acschex's Avatar
acschex
I am in south Louisiana, outside temperature should not have any effect on it. It will only run for a little wile starting with ether
Old Mar 11, 2013 | 01:10 PM
fordpride's Avatar
fordpride
The possible problem with it is the glow plugs could ignite causing detonation.
Old Mar 11, 2013 | 01:13 PM
fordpride's Avatar
fordpride
Where at in La. ?
I'm in Baton Rouge I may be able to come look at it for you.
Old Mar 11, 2013 | 01:21 PM
Hussler's Avatar
Hussler
What is the HPOP pressure cranking > 500PSI?
What is the fuel pressure cranking > 20 PSI?
If above is correct have you replaced the CPS yet?
Old Mar 18, 2013 | 11:41 AM
acschex's Avatar
acschex
We have replaced the CPS and the HPOP Psi is >500, I am not sure of the psi cranking at this moment, I will update as soon as I find out
91 7three
Apr 28, 2015 09:51 AM
deerdog
Mar 16, 2015 07:49 PM
beersy50
17
Jul 12, 2008 10:24 PM
Siturbod
Nov 23, 2005 07:05 AM
bz
Apr 10, 2003 10:51 PM
