Reading the Codes
Old Aug 12, 2005 | 06:56 PM
AnchorageAk.PSD's Avatar
AnchorageAk.PSD
Reading the Codes
Can the motor codes be pulled up by any obd 2 code reader or do u have to get pulled by the dealer.. 03 f-450 6.0
Old Aug 12, 2005 | 07:48 PM
Daryl Hunter's Avatar
Daryl Hunter
You can read them with the Superchips Microtuner or Diablo programmers. There are other code readers out there as well. Don't need to go to the dealer to do it.
Old Aug 12, 2005 | 09:49 PM
jasonschwenk's Avatar
jasonschwenk
but will they read codes even if the check engine light isn't on?
Old Aug 12, 2005 | 09:59 PM
Crash687's Avatar
Crash687
if there is any, some faults cause the light to come on others do not.
Old Aug 12, 2005 | 10:01 PM
kw5413's Avatar
kw5413
I think more don't...than do.
Old Aug 13, 2005 | 01:21 AM
Daryl Hunter
Yes, the SCMT will read codes at any time - check engine light or not. I believe the Predator will as well.
Old Aug 13, 2005 | 07:47 AM
npccpartsman's Avatar
npccpartsman
Yes--the Predator will, 'cause the EGR disconnect never causes a CEL and it causes 3 codes in my truck
Old Aug 13, 2005 | 08:38 AM
jasonschwenk
but what about a regular obdII code reader will it also clear these codes?
i have the edge juice/attitude and i want to disconnect the egr but i am worried about the codes
Old Aug 13, 2005 | 10:42 AM
wb6anp's Avatar
wb6anp
You have to make sure the code reader is CAN capable these trucks are not exactly OBDII like the ford cars. I had to upgrade my code reader to be CAN capable to read my truck.
