Taurus AC/heater Blower question
I've found what I think is a good deal...a '93 Taurus wagon in excellent shape: 71k old lady miles with documented service, 3.8 liter motor (wanted the 3.0, but oh well...we'll save for the head gasket), recent trans rebuild by Ford, and new PS pump and lines. Price is $2,000 because of low miles, but the lady doesn't need to recoup trans rebuild costs as it was done under warranty.
One little issue is the heater/AC fan only works on two settings...off and high. I can live with it, but wife can't. Too noisy. My Haynes manual show the switch replacement and the blower fan replacement as doable...but I was wondering which is the problem, or could it be something else?
To be clear...of the 4 or 5 settings the fan switch offers only off or high works. Has anyone else had this problem, and/or how can I troubleshoot this?
Thanks guys,
Erik
I have a '93 wagon in my yard, I'm trying to sell for $2K, only 78K miles and the 3.0! Too bad you're on the other side of the nation
I'll have to go out and look at it now...
Connect a meter across the blower fan connections and try the switch at different settings. There should be a change in voltage shown.
OR - if it's the kind that has a bank of resistors on the blower housing, the voltage should appear at different contacts (one for each resistor) as the switch is moved to each setting.
If the voltage is where and what it's supposed to be, the switch is working. And so on...
The idea is to "PROVE" that one part or the other either IS or IS NOT doing what its supposed to do.
Krewat, yes it is one of those with a resistor, according to the manual. But the troubleshooting procedure in the manual allows for it. I'll know more tomorrow when I take possession of the car.
If for some reason I can't figure out the testing, there's gotta be a ton of switches, resistors and fan blowers in the wrecking yards.
Thanks guys.
Given that it's easily reached under the dash by the passengers feet, and that a nearby junkyard had one for $5, I decided to be lazy and just replaced it without fiddling with the dashboard and testing the switch and fan motor.
Works like a charm! It helps that Ford used the same resistor in all Taurus' at least up through '95.
