Front Drum Sticking
Old Aug 11, 2005 | 08:36 PM
heel&sole's Avatar
heel&sole
Front Drum Sticking
I had to replace the front drum and shoes on a '72 F100 (2 whl drive) because I waited too long to check it after it started pulling to the right when braking. I had metal-to-metal contact all along the most outboard 1/4" of the shoes and drum.
So I just put together the new shoes, new drum mated to the old hub and bearings. The drum will not spin freely even with all slack taken up in the adjusting nut. Something seems out of round.
Any advice?
Old Aug 11, 2005 | 08:48 PM
tex1264's Avatar
tex1264
is your brake shoe nails in the right holes on the backing plate? thanks kevin
Old Aug 12, 2005 | 05:29 AM
heel&sole's Avatar
heel&sole
I am pretty sure they are, but after work today I'm going to take the drum off again and double check my set up...
Old Aug 12, 2005 | 08:41 AM
qman's Avatar
qman
Sticking could be caused by a bad cylinder.
joegeds
May 31, 2016 08:11 PM
1950FordF1
Nov 28, 2015 10:40 AM
bronco7856
1978 - 1996 Big Bronco
Nov 22, 2015 10:17 PM
tonyford
Escape & Escape Hybrid
Oct 7, 2012 08:31 AM
Roger Carter
Feb 22, 2012 06:38 AM
