360 Engine
Old Aug 11, 2005 | 08:39 AM
77 Bronco's Avatar
77 Bronco
360 Engine
I have a 360 Engine bored .040" over. I think it is a '77 Block. It has a stock hydraulic cam w/lifters, push rods, rocker shafts, crank damper, water pump and crank pulleys, timing cover, New Timing Set, oil pump & pickup (rear sump), New .040" Pistons/rings, New bearings, '72 Heads w/new valve guides, seals, valves, valve job. The engine has all the pistons, rods, cam, lifters, timing set and crank installed. Heads are off the engine. Engine has less than 200 miles on it. What would a set up like this be worth with all the machining and new parts I have into it?
Old Aug 11, 2005 | 10:22 AM
rusty70f100's Avatar
rusty70f100
It all depends who you sell it to. The crank and rods aren't worth much of anything. The block might go for $200. Heads, $100. You'd probably be farther ahead to just run it.
Old Aug 11, 2005 | 10:28 AM
Mike G's Avatar
Mike G
It'd be worth $800 to me, if I needed a 360 for something. Considering you can pick up a remanned motor with warranty for a few $$$ more...
--Mike
Jesser02EX
22
Oct 18, 2015 08:10 PM
rickpilgrim
Oct 30, 2011 08:46 AM
desoto dave
Jan 9, 2009 05:24 PM
ADSf100
Mar 28, 2003 04:59 AM
67 428 Fairlane Ranchero
Jan 30, 2003 08:12 PM
