67 Lowering / Drop Question?
Old Aug 10, 2005 | 10:04 PM
johndavidrichard's Avatar
johndavidrichard
Ok, I'm about the make the leap. I talked to Steve at AIM regarding options for lowering my 67 F100. I'm going to go with the axle relocation kit for the back with shock extender brackets. Should lower the back 6" in this config.
My only hesitation is on the front end. Do I really need the drop I Beams?
Is there no other way to lower the front 4" without spending $500.
Just wanted eveyones feedback before I take the plunge.
Thanks
JohnR
Old Aug 10, 2005 | 11:11 PM
Ford_Six's Avatar
Ford_Six
Drop beams are pretty much the cheapest way to keep the camber and caster angles correct. The only other way would be to put a full-blown IFS system in it, but then you lose strength and durability. I don't think re-bending the beams would be a very good idea for that much of a drop, since your angles will be way off.
Old Aug 16, 2005 | 08:53 PM
ct.russ's Avatar
ct.russ
i cut 2 coils off the front but i think that its too much.. i wont know untell its all back together .. but the angle looks like its going to shread tires oops .. oh well have to put the other coils back in ... lol
