2001 Explorer, hissing noise
Old Aug 10, 2005 | 07:16 PM
jcgriffin's Avatar
jcgriffin
My son has a 2001 Explorer with the 4.0 engine and is away at college (far away).
Lately the the engine doesn't run right, if it starts, he must keep the accellerator almost fully depressed to keep the engine running. Some times it will start, and some time it won't.
He opened the hood, didn't see any thing abnormal but did hear a hissing noise as a fellow student worked the accelerator. A fellow student (works as a mechanic at GM dealership) said the plenam looked like plastic and thought the heat from EGR might have cracked the plenam.
Has anyone had this happen before, know what might be going on here?
Regards, JC
Old Aug 11, 2005 | 08:24 PM
jcgriffin's Avatar
jcgriffin
My son to his truck up the Ford dealer today, and they said it needed an IAC.... In case someone else has the hisssing air noise and a truck that won't idle.
Regards, JC
Old Aug 11, 2005 | 08:26 PM
ledbetter's Avatar
ledbetter
It's a common problem. There's more info in the sticky thread at the top of this forum.
Old Aug 12, 2005 | 06:52 AM
ledbetter's Avatar
ledbetter
Sorry, I thought it was at the top of this forum. I think it might be in the Ranger forum, but in any case, it's a very common problem.
Old Aug 12, 2005 | 07:16 PM
vicv's Avatar
vicv
A hissing noise is ususally a vacuum leak. It will cause a rough idle/stall condition. The IAC is a common problem but if you have a vac leak too it won't fix the idle issue. Check for vac leaks.
marcomjl
Jan 24, 2011 08:49 PM
custom1106
Nov 21, 2010 08:26 AM
Sycostang67
Feb 9, 2006 10:41 AM
SprintRacer26
Jan 12, 2005 10:55 PM
Kundalini
21
Jan 23, 2004 05:40 AM
