whats this noise? 99 PSD 7.3L
I'm new to diesels, and I noticed today while driving down the street ~ 40mph a hissing noise coming from under the hood. When I lifted off the gas it would go away until the engine was at an idle and start hissing again. When I gave it gas to keep the speed up the noise would go away until the engine leveled off then it would hiss again.
From researching this forum I'm guessing a EBPV problem? If so what is the easiest way to confirm this problem?
The truck runs good but the hissing noise is loud enough to make it annoying...plus I dont like to let things go, if it requires replacement I'd rather do it now instead of it causing other problems elsewhere.
What is the outside temp? How long did you let your truck warm up?
Mine will do the same thing if I have to take off before it really warms up, but when it does warm up it stops.
When it's cold out and you start your truck can you hear that hissing? kind of like a jet taking off, well, that is the hissing sound. If you were to sit in the bed of your pickup you would hear that sound as you are driving. I talked to my wrench and he said I just need to let my truck warm up longer, remember these diesels love to be warm so does your trans. I installed a heater in my garage so I don't need to have my truck run so long in the morning.
I hope this helps.
I hope this helps.
With my park brake on (6-speed) it will go to high idle with the valve closed. Never had a problem until it was about 8 below 0 and (farenheigh sp?) and was fully warmed up and I was going down the road and it would kick open and shut so I pulled over, shut it off and started again and it stopped. Came home and disconnected with no more problems.
So that is what the noise is when I drive on a cold day! The first time it did it, it scared me. It only does it at slight throttle, going about 10-15 mph, and the engine actually seems to lose a little power because the truck slows down. I would call it more of a muted roar then a hissing sound though.
I can either slow down to make the noise go away, or speed up and it also goes away. It only does it when it is cold, and the engine is first started for the day.
First I would like to say hi to everyone. This is my first post, but I have been visiting the site for about a month to learn everything I can about the PSD. I must say that I have really learned a lot! I have a 1997 F-250HD with a 7.3PSD in it and it also makes this same hissing noise. I do not think that it is the EBPV. I have driven the truck when it is cold (in the teens and twentys) and I know what sound that makes. On my truck it is more of a groan than a hissing noise. My motor will make the hissing noise at idle (it is faint), but it is more noticeable when moving at a constant speed (you can easily hear it with the radio off). It makes the noise when the motor is at operating temperature, and does not seem to affect the performance of the motor in the least bit. When you give the motor more throttle, it completely goes away instantly, and it is also gone when you are coasting. It is enough to drive me crazy. Does anyone know what this is? Do you think it will hurt my engine in the long run?
When was the last time you changed you air filter and fuel filter? Mine was making this noise before today, I had my truck serviced and asked them to change my fuel filter and put a new air filter in. Man it starts great, and I don't have that noise anymore. I do change my fuel filter ever other oil change.
Seabiscuit
17
02-09-2009 09:13 AM
