stuttering stanley
Old Oct 10, 2002 | 11:31 PM
anotherF150's Avatar
anotherF150
stuttering stanley
My 460 is cutting out at 3 grand I have everything froom MSD box to NGK V-Power plugs everything ts new and set right. But it still cets out. Any advice?
Old Oct 11, 2002 | 12:38 AM
Torque1st's Avatar
Torque1st
Posting Legend
stuttering stanley
Fuel?
Old Oct 12, 2002 | 04:42 PM
anotherF150
stuttering stanley
Like a filter, accelerater pump? Because it starts and runs fine it even still has great throtle response.
Old Oct 13, 2002 | 12:16 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
stuttering stanley
RPM limiter?
Old Oct 13, 2002 | 08:39 PM
proeliator's Avatar
proeliator
stuttering stanley
While there are many things it could be, I would probably first through a timing light on it and check your initial timing, and then your total timing, and when it comes in. It should be @12 initial and 38 total in around 2600rpm. I don't know if you just have the msd box or the total package, vacuum or mechnaical advance. It could be the advance malfunctioning. If that all checks out, I would look at fuel delivery. Let us know what you find out.
Old Oct 14, 2002 | 01:34 AM
anotherF150
stuttering stanley
The timing is set a little in advance and it is a vaccume advance distributer. I played with the timing for a while but it still cuts out at a constant high RPM. The only thing I can think of is too little fuel presure.( it has a stock fuel pump and lines )
Old Oct 14, 2002 | 01:48 AM
Torque1st's Avatar
Torque1st
Posting Legend
stuttering stanley
Have you checked the choke? Is it opening? Does it miss the same with a load on the highway as it does sitting in your driveway? Does your MSD system have a rev limiter? Is it malfunctioning? Try re-installing the OEM ignition system.
-Just some thoughts...
Old Oct 14, 2002 | 03:27 AM
Custom Junk's Avatar
Custom Junk
stuttering stanley
Landscapepro
Jan 13, 2013 07:36 PM
Ibuildembig
Dec 23, 2011 05:20 PM
forddriver17
Offroad & 4x4
Jun 8, 2009 09:48 AM
Twin Tritons
Alaska Chapter
Oct 28, 2006 10:33 PM
