I've done a search on this topic, but most apply to EB or Limited Explorers that have the console computer. My XLS doesn't, so there shouldn't be an LOM.
My driver side low beams don't work. The high beams are fine. I replaced the bulb and no luck. I replaced the multifunction switch and no luck. The new bulb does work becuase I've plugged it into the passenger side. Test voltage and seems to be there at the harness. Any other suggestions?
have you checked the return (ground) at the harness. You may have a break in the wire? If you have 12VDC there then the bulb should work, sounds like it is not completing the circuit.
Welp, that's what I'm guessing. There's probably a short in the white/lt green wire. I've temporarily ran a wire from the other headlight to the white/lt green wire closer to the headlight and low beam comes on. Not sure if that other headlight circuit can take the extra load. But it looks like it'll have to work until I have time to figure out where that short is.
