Clutch Advice, Please
Old Aug 12, 2005 | 03:04 PM
ramtoo's Avatar
ramtoo
I got a complete clutch kit from a company I saw om ebay for 49.00 with shipping, disk was rebuilt but all the rest was new the only thing that did not fit was the pilot bearing too small but my old one was ok. I went to harbor freight and bought a trans jack for $75.00 worked great . Don't think that little trans in not extra heavy! To reant a jack was $50.00 and day so I just bought one. Clutch is over a month old and working fine, had to adjust the play after the first week. You also might look at your center carrier bearing if you have a split drive shaft this is a good time to change it out!
Old Aug 12, 2005 | 11:36 PM
The_Ryan_Lilly's Avatar
The_Ryan_Lilly
10 or 11 inch clutch? It could be either. Both will work but a 11" clutch needs a 11" flywheel and a 10" clutch needs a 10" flywheel. The actual overall size of the flywheel is the same, its the friction surface for the clutch disk to contact that is different.
The only way to know if you have a 10 or 11" is to take it out and check, then have the flywheel resurfaced and buy the right size clutch. hopefully you can get the flywheen back the next day and install the clutch.
If you fing a good deal on a new clutch disk/pressure plate/flywheel all together then it doesnt matter what size was in there.
Old Aug 13, 2005 | 02:41 AM
horlchoo's Avatar
horlchoo
Here are a couple thoughts I would like to add....
1) You can grind down the threads on a bolt not quite small enough to fit inside
the pilot bushing. Grind the threads until the bolt just fits inside the hole. Fill
the cavity behind the pilot bushing with grease, then insert the bolt. A good hit
with a hammer will pop the pilot bushing right out (the first time I did this
it took two hits with the hammer). Hydraulic pressure is nice?
Then all it took was a big mallet to get a new one in basically (after cleaning
out the grease so I don't make a mess). I still have that bolt and may be
using it again soon. (Cost: at most a couple bucks if you don't already have
a bolt)
2) On more than a couple occasions I have dropped a transmission from a
truck with an engine hoist. I just push the boom of the hoist into the cab
and attach a lift chain to the top of the transmission (after trans cover removed). Then after the chain slack is taken up, the driveshaft dropped, and the transmission crossmember removed, the tranmission is unbolted and backed off then dropped to the ground. Then just unhook and slide the trans out of the way..
I have a transmission jack adapter for a regular jack, but it doesn't fit
my regular jack well. I used an engine hoist one time when I had to replace
clutch fork pivot hardware, then again for replacing clutches.
Old Aug 13, 2005 | 02:49 AM
horlchoo's Avatar
horlchoo
Oops, sorry, I forgot to add that I used an engine hoist to drop T-18's which are
pretty heavy. I didn't even consider that the transmission mentioned in this
thread might be lighter and not have a removable cab floor cover.
nobleart
Mar 27, 2008 10:09 PM
sissini
Feb 25, 2008 07:58 PM
F150Lariat79
Sep 13, 2004 08:40 PM
ratwell
Aug 8, 2003 05:21 PM
masterbeavis
Apr 18, 2002 01:22 PM
