clutch replacement advice?
Old Aug 7, 2003 | 07:53 AM
ratwell's Avatar
ratwell
clutch replacement advice - also posted in 67-72 Truck
Some help please,
I must replace the clutch in 69 F100 - 360 - 3 spd (used to be on column).
I found a thread from 6-2002 that suggested Centerforce clutch and double friction pressure plate and throwout bearing---
I have never done this - Is there a complete set of INSTRUCTIONS available somewhere?
How many hours/days should I expect?
Difficulty level for a mechanically inclined engineer?
Two things I have heard repeatedly are resurface flywheel and buy alignment tool. Any other MUST Do's for a happy ending.
Are there wear points or broken things that an experienced mechanic would look fo while it is apart?
Thanks in advance,
Richard and son
Old Aug 8, 2003 | 03:39 PM
fordin K's Avatar
fordin K
you might be refering to the dual friction. it provides more holding power over stock, I think 90% but the way it is set up, it will keep close to stock feel on the pressure plate engagement. as for the resurfacing, it is a must for optimum performance. for the alignment tool, if you have a friend that has one, perfect, if not a local parts store should sell a universal set for around $25. or rent (no place here ) it is just used to align pressure plate/disc to pilot bearing while mounting to flywheel. along with the clutch kit, should be instructions. while apart, spend the $10 or what ever, replace the throwout bearing. The kit should have a pilot bearing included, if not change for that you will need a puller. I think that's the basics. ooh maybe rear main seal if it's leaking.... good luck
Old Aug 8, 2003 | 04:14 PM
ratwell's Avatar
ratwell
thanks,
The sachs kit came with clutch, pressure plate, throw out bearing, and pilot bushing as well as alignment tool
I will pass on the rear seal unless it is leaking. because of oil pan, pump, jacking up engine etc.
richard
Old Aug 8, 2003 | 04:19 PM
GR8Diesel's Avatar
GR8Diesel
Best alignment tool is the discarded input shaft of a scrap transmission.
Old Aug 8, 2003 | 05:21 PM
ratwell's Avatar
ratwell
thanks to all,
I think the tool in the kit is good.
I will try it this weekend but not attempt the rear seal unless absolutely necessary.
Richard
Divingjack
N. California Chapter
Jun 14, 2014 04:48 PM
Richard W. Reed
23
Jul 25, 2010 05:53 PM
Forever Fords
Ontario Chapter
Oct 22, 2007 08:41 PM
Richard Forster
Oct 30, 2006 11:35 PM
