lil help removing bed bolts please?
Old Aug 7, 2005 | 10:38 PM
HATCHETT's Avatar
HATCHETT
Im converting my 78 F250 to a flatbed. I was workin on all the bolts that hold the bed to the chasis and a few of them will turn but the top part turns also. how am i supposed to keep the top piece from moving? or is there an easier way?
Old Aug 7, 2005 | 11:13 PM
77F-150's Avatar
77F-150
Use a vice gripe and clap it on the top part of the bolt and have someone hold it while you take off the bolt from the bottom.
Old Aug 8, 2005 | 04:42 AM
billybob_81067's Avatar
billybob_81067
I've done this a few times and I usually just torch off the top of the bolt and then drive the shaft of the bolt down through the frame...
Works like a charm!
Old Aug 8, 2005 | 06:25 AM
skips69's Avatar
skips69
Unfortunately, I too end up cutting the heads off of most of them because they have the bad habit of turning. I usually use a grinder though, so that's an option as well. Regardless, I always replace the bolts and hardware anyway as they are usually pretty bad here in the midwest...........
Old Aug 8, 2005 | 07:45 PM
dynamic's Avatar
dynamic
If you got a welder, you could always weld a nut, or a bar to the top of the carriage bolt and have someone hold the other side. The first time I tried removing these was with a torch, left me with some extra holes in the bed... lol... just my experiences...
Old Aug 8, 2005 | 08:20 PM
Mil1ion's Avatar
Mil1ion
As a reader can I suggest putting the topic in the title so we know what's coming ?
ie: *Removing Bed Bolts*
Old Aug 8, 2005 | 08:36 PM
FordPickup460's Avatar
FordPickup460
This works well. The bed on my dads 97 F350 had loose bolts and we couldnt tighten them without the bolts turning, so we welded 5/8 nuts to the top of the bolts, my dad held a wrench on the nut underneath, and I tightened it from the top. When done, grind the nut off and its good to go. Be carefull not to melt the bedliner like we did
Old Aug 9, 2005 | 12:02 AM
tankglh21's Avatar
tankglh21
yeah i just torched all my bolts off. i have a '78 also and couldnt find a good bed for it so i bought a '93 f-150 bed. sorry for going off topic a bit
Old Aug 10, 2005 | 10:50 AM
Hyperactive460's Avatar
Hyperactive460
if you don't have a welder or torch you can center punch the head of the bolt and drill it out, a 1/2 drill bit will take enough of the head off to drive the bolt thru.......
Old Aug 10, 2005 | 11:00 AM
conter4x4's Avatar
conter4x4
cut the bolts off thats about the easiest way to do it.
Old Aug 10, 2005 | 01:21 PM
nhswrld's Avatar
nhswrld
easiest way is to torch off the bolts from underneath, or get a cutoff wheel..cut an X on the head of the bolt then just use a flat chisle and a hammer...pop the heads right off...
Old Aug 16, 2005 | 10:07 PM
rhino3's Avatar
rhino3
If you have a welder just put a good spot weld from the head of the bolt to your box floor and then rattle away with the impact, they will usually either come loose or twist off. I would recommend spraying them down with some PB Blaster or good penetrating oil first.
