Crack in frame
Old Aug 7, 2005 | 08:22 PM
F-150 questions's Avatar
F-150 questions
Crack in frame
hello
i'am putting a stage 1, 6 inch pro comp lift in my 1991 F150 Lariat i was told that i might be better off going with a stage 2 because it comes with a longer set of radius arms. i'am told that with the stage 1 the shorter arms have a tendency to crack the frame. i was just wondering if this was true or if anyone has had any problems with it? Thnx in advance
Old Aug 7, 2005 | 11:28 PM
MustangGT221's Avatar
MustangGT221
Yes it is true. It could crack the frame rail where the drop radius arm bracket bolts to the frame.
They're talking about two choices....the stock radius arms using a new bracket to drop the end of the stock radius arm.
The other is using the stock radius arm bracket but with a longer radius arm. The longer arm has enough movement that you don't need a drop bracket.
Since the drop bracket moves the end of the radius arm further away from the framerail, it adds leverage to the forces it applies to the framerail. This can cause it to crack.
Typically, those kits are made for people who wanted a lift kit and don't really drive it hard off road. It's more of a mall cruiser kit. If you flex that suspension often, it'll be putting a lot of stress on that framerail and could crack it.
Old Aug 8, 2005 | 04:14 PM
F-150 questions
ok, thnx for the help again. much apreciated
Old Aug 8, 2005 | 10:09 PM
turboguy's Avatar
turboguy
WOAH! WHAT! I installed a kit with drop radius arm brackets not too long ago... I didnt know that! Is there any way that I can prevent my frame from cracking?
Old Aug 9, 2005 | 08:12 PM
MustangGT221
Weld the bracket to the frame, and don't articulate the suspension off road a whole lot
Best thing to do, would be to buy the extended radius arms and put the stock brackets back on. It looks a heck of a lot better too, I like how you can see the red radius arms in my suspension.
I have red suspension components and I carried that through to the 393's red dress up stuff. Gallery.
Old Aug 9, 2005 | 08:18 PM
turboguy's Avatar
turboguy
will do that... Do you know exactly where the cracks occur? I would also like to create a brace of some kind at that point.
Old Aug 9, 2005 | 10:54 PM
MustangGT221
Maybe welding a 1/4" plate behind it would help...I havn't picked up on crack patterns.
swoosh1958
New Member Introductions
Jan 1, 2017 12:40 AM
green_95
Nov 28, 2016 11:10 PM
bsa_bob2
WTB - Parts & other
Dec 1, 2015 09:46 PM
workin hard
Oct 20, 2003 07:53 AM
benz302
Apr 29, 2002 08:24 PM
