400m compression
Old Oct 19, 2003 | 06:04 PM
workin hard's Avatar
workin hard
400m compression
I'am getting ready to do a re-built on a 79 F250 400. This truck is used to plow snow in Michigan so I'am after big power at low end. I was all set on Badger 9:1 but the machine shop I'am going to use said it would be a bad idea to raise the c/a on a motor for this type of use. What to you guys think??? Please do not say drop in a 460.
Old Oct 19, 2003 | 06:14 PM
Matts72's Avatar
Matts72
It should be just fine, don't go any higher on the compresion though, these motors came with a 8.0-8.2:1.
Good luck on the build up, let us know what your combination is.
Old Oct 19, 2003 | 07:36 PM
daveee's Avatar
daveee
Look at any Ford or GM gas engine built for heavy duty applications. They all are low compression engines. There is a reason for this.
Old Oct 19, 2003 | 07:39 PM
danlee's Avatar
danlee
In addition to the Badger pistons, get a Cloyes double roller timing set and install the crank gear at zero degrees. Then you need a good high lift camshaft.
Check out this article.
http://www.projectbronco.com/Technic...e_build_up.htm
Old Oct 19, 2003 | 08:32 PM
danlee's Avatar
danlee
Here is a great hydraulic roller camshaft. It will give you great low end torque with a dual plane intake and headers (even without). The intake valve closing angle of 76 degrees will knock that 9:1 Static Compression Ratio down to 6.5 to 1 Dynamic Compression Ratio. This is below the low end of acceptable DCR.
Series & Grind Number:
PowerMax HR-228/345-2S-12 Hydraulic Roller Dual Pattern
Part Number 529801 (Cam Only)
Suggested Retail $336.00
For additional Ford "Cleveland" applications, use the menu below
More Ford "Cleveland" SystemsStrong Performance - 529541Serious Performance - 529551Serious Performance - 529801Radical Performance - 529811Back to Engine ListingNon-Hydraulic Roller Motorsports Systems
Cam Specs
Degrees Duration @ .050 Int./Exh. Degrees Advertised Duration Int./Exh. Degree Lobe Separation Open/Close @.050" Cam Lift Int./Exh. Lash Hot Int./Exh. Gross Lift Int./Exh.
228
232 290
294 112 7 41
53 (1) .000
.000 .597
.609
There should be an RV type hydraulic roller with an earlier 'Advertised' IVC. I calculate about 48 degrees should be right for 9:1 CR.
Old Oct 20, 2003 | 07:53 AM
danlee's Avatar
danlee
Here is another Crane cam that should work well with 9:1 CR. It is a flat hydraulic lifter cam and much cheaper than a roller. It doesn't have as much lift as that roller, but the IVC is better at 61 degrees. The Dynamic compression ratio is 7.46:1. It will still produce a lot of low end torque, and you can probably burn 87 Octane fuel.
Part Number: 523904
Grind Number: H-260-2 (REPLACES HMV-260-2)
Engine Ident: 1970-1982 FORD-MERCURY V-8 BOSS 351-351C-
351M-400 CU.IN. SMOOTH IDLE, DAILY USAGE,
OFF ROAD, LIGHT TOWING, ECONOMY
VALVE SETTING: INTAKE .000 EXHAUST .000 ----> HOT
LIFT: INTAKE @CAM 2847 @VALVE 493 ROCKER ARM RATIO
EXHAUST @CAM 290 @VALVE 502 1.73
ALL LIFTS ARE BASED ON ZERO LASH AND THEORETICAL ROCKER ARM RATIOS
CAM TIMING OPENS CLOSES ADV DURATION
@ .004 INTAKE 19.0 BTDC 61.0 ABDC 260.0 °
TAPPET LIFT EXHAUST 69.0 BBDC 27.0 ATDC 276.0 °
SPRING REQUIREMENTS
TRIPLE DUAL OUTER INNER
PART NUMBER 99837
LOADS:
CLOSED 90 LBS @ 1.828 OR 1 53/64
OPEN 255 LBS @ 1.348
RECOMMENDED RPM
RANGE WITH MATCHING COMPONENTS
MINIMUM RPM 1500
MAXIMUM RPM 4500
VALVE FLOAT 6500
CAM TIMING OPENS CLOSES MAX LIFT DURATION
@ .050 INTAKE (5.0) ATDC 29.0 ABDC 107 °ATDC 204.0 °
TAPPET LIFT EXHAUST 44.0 BBDC (10.0) BTDC 117 °BTDC 214.0 °
bigmark
Paint & Bodywork
Jun 14, 2016 05:14 AM
70-360fe
Jan 1, 2013 11:47 AM
Fordenstein86
User Gallery & Picture Display
Jan 7, 2012 11:30 AM
unclejunk
May 10, 2010 09:48 PM
workin hard
25
Mar 19, 2003 09:34 PM
