Engine stalls when put in gear
Old Aug 7, 2005 | 01:17 PM
JoeWandaHayley's Avatar
JoeWandaHayley
Hello, I have a 2000 Ford Ranger Ext Cab 3.0 V-6 and I am having probs. Truck runs just fine in park but hesistates and dies when put in gear and brake is released. I have changed fuel filter and pump/sender unit, checked IAC, scanned for codes reader said "MIL Open", I need help. Truck will continue to run if gas pedal is held down.
Old Aug 7, 2005 | 08:54 PM
Gary B's Avatar
Gary B
sounds like a stuck IAC you can try tapping on body of it and see if it helps. if so clean or replace it.
Old Aug 8, 2005 | 09:30 PM
JoeWandaHayley
Bolted on new IAC had the same problem.
Old Aug 16, 2005 | 03:29 PM
JoeWandaHayley
PROBLEM SOLVED!!! There was a short in the wire to the ignition. No more stalling or hesitation once put in gear. My 2000 Ranger is back to normal after troubleshooting & replacing unneccessary parts for over 2 weeks. Unfortunately, I didn't resolve the problem, I had it hauled to a FORD dealership for repair.
Old Aug 16, 2005 | 03:50 PM
Rockledge's Avatar
Rockledge
Glad to heart it's fixed. I wouldn't have suspected an ignition problem.
mustangnewby
Aug 19, 2014 02:01 PM
Burburan
Mar 27, 2014 09:57 PM
kklblue
Aug 1, 2011 05:46 PM
fiddy dollars
1983 - 2012 Ranger & B-Series
Nov 28, 2010 09:59 AM
daypray1
2004 - 2008 F150
May 20, 2008 05:51 PM
