Tire fit?
Old Aug 7, 2005 | 10:38 AM
sniper4x4's Avatar
sniper4x4
Tire fit?
1995 f-150 4x4
Recently while shopping for tires and lift kits I was pricing a 2" suspension lift but was told by the shop thatmy truck with the quad shock front end has taller springs which is equivalent to a 2 inch lift.
Several online tire fitment guides show that a 33x12.50 tire will fit my truck w/ a 2 inch lift. SO will 33's fit my truck as is? I currently run 31x10.50 BFG AT's on the factory 15x7.5 rims.
Old Aug 7, 2005 | 10:42 AM
MustangGT221's Avatar
MustangGT221
The 33s would fit with the 2" lift. They would be a smidge bit tight by my standards, but enough room that they would clear. They'd probably rub on the radius arm at full turn but thats what happens to all of us, almost unavoidable. It's nto that big of a deal, most just change the setting on the steering lock so it won't actually turn that far.
A truck with quad shocks is just as tall as a truck w/o them. It's just that...optional 2nd shock.
Old Aug 7, 2005 | 07:06 PM
McLeod's Avatar
McLeod
I had a Rancho 4" lift installed with new lenghtened radius arms on my '93(Done in '95).
The 33 x 12.50 tires fit well with this lift and have plenty of "air" around them ( I don't like the look of tires crammed into wheel openings).
The tire do rub on the radius arms ONLY when backing up and the steering is at full lock.
I don't think I'd be too happy with these tires if I had anything less than 4" of lift.
This might not happen if the stock radius arms had been retained.
Old Aug 7, 2005 | 10:59 PM
MustangGT221
Interesting. Mine rub pretty bad when turning, but I'm running 35s. It barely rubs when I go in reverse. I have skyjacker extended radius arms. They are also bent in a little to try and get more clearance for the rubbing. Still rub. Most do what I do about being better in reverse because of the way the suspension moves after changing direction. You're pulling on the radius arm vs pushing. The placement of the bracket for the radius arm may have to do with this.
It's gotten a lot worse then it used to be. I lost about an inch in my front suspension when I swapped out the 302/M5OD trans for the 393/ZF trans. Which is also making me rub my fender a lot more often.
Old Aug 8, 2005 | 01:36 AM
lvmyf-150's Avatar
lvmyf-150
I Have 6" Superlift Lift On My 95' I'm Running 35 's I Use Drop Brackets For The Stock Radius Arms And They Barley Rub
Old Aug 8, 2005 | 09:16 AM
McLeod's Avatar
McLeod
One more note 33x12.50 tires(per my experience).
The disc brake fluid lines rub the tires occasionally. I have to keep eye on them. I ended up spliting a heavy fuel line in half and zip tieing to the brake lines to help protect them.
One more down side is that the wheels have so much offset that the "pivot point" of the turning radius is located inboard of the wheels resulting in the wheels "arcing" on the pavement when steering. Ideally the pivot point should be located near the point where the rubber meets the road. No big deal for hiway driving, but lower speed manuevering results in excessive force being placed on steering components and the frame area around the steering box.
I had to have the steering box / frame area rebuilt twice in 50K miles of driving. The last time they opened up frame area and really beefed it up. No probs after that.
Have Fun!
Old Aug 8, 2005 | 09:57 AM
MustangGT221
I have skyjacker extended brake lines and flipped my calipers so that it would put a twist in the brake line. I do not have them wire tied, didn't want them rubbing on anything, so they just sit in air and when you turn the wheels side to side they don't rub.
Old Aug 8, 2005 | 10:21 AM
McLeod's Avatar
McLeod
Interesting. I'll have to check into that.
dontknowmyalphabet
13
Jul 5, 2011 04:02 PM
jay_d
18
Aug 30, 2008 05:25 PM
impact
Offroad & 4x4
Oct 24, 2002 07:05 PM
muddogin400
1978 - 1996 Big Bronco
Sep 3, 2002 11:12 PM
