E4OD TCC still "Hunting"
Old Aug 6, 2005 | 04:10 PM
1OldGoat's Avatar
1OldGoat
I've posted questions on this before a received help and I have made changes to the truck but the problem persist.
I have a 1991 Ford F250 Diesel with an E4OD transmission. When the Check engine light was on the Code was for a Speed Sensor. I was also informed that the FIPL switch could also be bad and how to test. The FIPL/TP had the wrong voltages so I replaced it and the vehicle speed sensor. The FIPL now reads correctly but the problem persisted. I then, through alldata found that a bad Engine Speed sensor caused the same problems as I was experiencing so I replaced that as well. Problem is, the TCC still disingages and re-ingages as I'm going down the highway. I no longer have the Check Engine light and I show no error codes so now what do I do? (Other then take it to a shop which is what I seem to be headed for)
Old Aug 6, 2005 | 07:06 PM
PLC7.3's Avatar
PLC7.3
I suggest you look at oal connections to the trans....especially the on the one behind the heat shield pax side. Check for corrosion and bent pins etc etc.....
Special note:
To remove the solenoid plug, remove the heat shield."Do not use pry bars or screw drivers in attempt to remove plug" without shield removed.
Remove solenoid body connector by pushing on the center tab and pulling the wire harness.
To replace push down on solenoid connector until audible click is heard, then replace heat shield.
Old Aug 8, 2005 | 01:37 PM
evil tim's Avatar
evil tim
My truck was doing this for a while. What it turned out to be was a corroided relay on the fire wall. Talking to some of my buddies they daid that it is pretty common for the washer fluid to be spilt all over the relay when refilling and corroiding the relay and the diagonistic connector.
good luck
Old Aug 23, 2005 | 09:01 AM
1OldGoat's Avatar
1OldGoat
To anyone interested, the plug behind the heat shield had become dirty. I cleaned it and all works well.
TCC problem was the dirty plug. (TCC was locking then unlocking when cruising)
Check Engine light was the FIPL switch (Votlage was .6 at Idle, .8 at WOT)
Anit-Lock light was the wheel speed sensor on top the differential.
All these hit at the same time. A big Thanks! to all those that helped.
FORDF250HDXLT
117
Feb 10, 2025 11:29 PM
guisepi
May 7, 2015 12:42 AM
Spank226
Oct 19, 2010 04:41 AM
Gman75
Jun 17, 2009 01:01 PM
kevind95
General Diesel Discussion
Jan 1, 2009 09:30 PM
