difficulty starting
Old Aug 6, 2005 | 11:27 AM
cprescott's Avatar
cprescott
difficulty starting
Recently I've begun having trouble getting my 91 Bronco to start. I use this vehicle for work on a delivery route logging about 140 miles a night/5-days a week. Through the course of the night it seems to become more and more difficult getting it to turn over. I make approx. 12 stops on this route at which each I have to shut the truck off and abviously restart when finished. At the end of my route I make the 60-miles highway trip back to the warehouse to unload. At this point I shut down again..and by now when I go to restart it will barely do so. Note: If the vehicle has sat for awhile or even over night it starts with absolutly no problems. Checked the battery and it's fine. The alternator, pullies and belt are all brand new. It does'nt seem like it could be the starter as it starts great if its cold?
Old Aug 6, 2005 | 11:45 AM
86 Bronco 2's Avatar
86 Bronco 2
I`ve had trouble like this before and as the the starter heats up it turns slower to the point it drags. It does sound like your stater if you say your charging system is OK.
Old Aug 6, 2005 | 12:04 PM
cprescott's Avatar
cprescott
I've heard and read some threads stating that to be the problem..which does seem to make sense in this case. What did you do to fix this? Would a new starter help? It sounds like maybe this starter is getting burnt out. As I've had this route for about a year and had no problems the first 8-months or so. It's only been the past several months that it seems to have come on and getting worse.
Old Aug 6, 2005 | 01:30 PM
Franklin2's Avatar
Franklin2
Let's make sure we are all talking about the same thing. You mean it cranks very slowly correct? Or it cranks at a fairly high speed but won't fire and run?
Old Aug 6, 2005 | 03:44 PM
cprescott's Avatar
cprescott
Yes it cranks slowly and will usually eventually catch. It also seems that the longer I let it sit the easier it starts
Old Aug 6, 2005 | 03:57 PM
Franklin2's Avatar
Franklin2
The starter is a hard one to diagnose. That will probably be a replace and try it thing.
Have you taken any voltage readings at the battery? I would be curious to know what the voltage at the battery is with the truck off, with the truck running, and with the truck running and the lights and anything else powered when you make your deliveries.
Old Aug 6, 2005 | 04:33 PM
cprescott's Avatar
cprescott
Yeah I took it to a batteries plus the other day to test it..I don't remember the exact readings but they said with all three: the truck running, off and starting. I've got plenty of juice and it's holding its load well.
Old Aug 6, 2005 | 09:09 PM
Holmesuser01's Avatar
Holmesuser01
Have you checked the timing? It could be somewhat advanced.
houzer
6.4L Power Stroke Diesel
Feb 16, 2025 07:55 AM
MOOKIEX4
Jun 26, 2019 09:06 AM
Scrilla420
2004 - 2008 F150
Jun 30, 2015 09:15 PM
viperrtblck
Sep 11, 2006 11:21 PM
