Im installing a 6 piece grill insert on my 06 SD.The 4 horizontal pieces I could get the access I needed to attach the mounting harware.How can I access the space to mount the hardware for the 2 end verticle pieces?Do I need to pull the headlight or is there another way to do this.
THANKS GUYS
I got it guys,,,,thank you much.Theres screws at the top of the grill that let you access the backside,they were right there in front of me....
Thanks Guys
Can't you just pull the grill off, like on the 99-04's. The 4 little screws that hold it on on top of the grill.
Is the 2005 F350 grille the same physical dimensions as the 2004 F350? I would like to put a Billet Grille on my truck but I like the looks of the three piece kit compared to the six piece kit.
Your probably going to need to pry up on the spring loaded tabs on the bottom after you take the screws off the top. I use a computer mouse pad on my bumper and a flat pry bar to work them out.
Yep...it is from ford.Thats the grill they use in the chrome package,but you can get it if you dont get the chrome package option.Now that other package would even make a Dodge look good..LOL
