Can you turbo a 2.3/2.5 Automatic Ranger?
I know it's been asked so many times, but I never looked into it much. I was just wondering if you could bolt on a Turbo from a 85 Mustang SVO 2.3 or 85 Mercury Cougar 2.3 without too much trouble? What would you have to do to the stock 2.3/2.5 in the Ranger? Has anyone successfully done it? Could you keep all your accessories, Power Steering and A/C?
If you keep the boost down, you can adapt the turbo to a dual plug motor. Otherwise you should probably look into swapping the whole motor. Turbo 2.3L enignes have a different head (larger combustion chamber) and forged low compression pistons.
Sorry to disagree with you Jim, but a turbocharged 2.3L would knock the socks off of a 3.0L. Even if I knock my SVO down to 10 psi boost on the regular fuel setting it is still making 175-180 hp at the flywheel. Since most people doing these swaps don't bother with the octane switch and run full boost all the time, you're talking about a 200+ hp motor stock (assuming its an 86+ enigne).
Look on turboford.org, there's someone who is (or was) selling a 2.3T in an 86 Ranger. It still has A/C, power steering, etc.
SC_Dave
28
08-26-2015 09:34 PM
