My 1986 Ranger with a 2.3L FI engine has no power. When cruising at 55mph and climbing a slight hill it decelerates to 45mph, with the gas pedal to the floor. I have changed the EGR, plugs, plug wires, distributor cap & rotor, cat. converter, air filter, and checked air box. What am I missing? Any help would be appreciated.
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
I have not checked fuel pressure,but I will. As far as codes, is there a way to check them myself, or do I need to have special equipment. But I have standard size tires.
I don't know much about the early rangers, but you may want to pull the vacumn line on the fuel regulator. If it smells of gas it is bad and needs replacing. that seems to be a common trouble in these trucks. good luck.
Dave
The fuel pressure regulator is a good place to check as Dave suggested. I had a problem like yours a few years ago and my regulator was bad. It's the silver thing on the fuel rail with a little hose going into it. Could also be the fuel filter, or some weird electrical problem, like I'm having now...
Reason: typo
I really appreciate everyones input, I will try testing everything that I have been told to check. Although I have to wait till this weekend because I am on call, I will let you all know the results.
