Problems indentifying Block Casting Number...help!
Old Aug 2, 2005 | 10:10 AM
atdoman's Avatar
atdoman
I've got a hard question for you guys today and hopefully somebody will have the answer. I got a 67 bronco that's currently be restored and we've found certain things that have made us believe this is not the original engine. We've looked everywhere on the engine that people have told us but came up with nothing...except under the starter on the engine block. The question to everyone is the casting numbers don't match up with anything...we do however believe it's either a 289 or 302 because of the firing order on the back of the block but not sure based off number which one it is. Here are the numbers maybe someone can decipher them for us.
O0AE-6015E
Any help is appreciated.
Old Aug 2, 2005 | 09:23 PM
desertdave35's Avatar
desertdave35
I highly doubt its a O0AE-6015. Ford uses the Alphabet to represent the years, A=1940, B=1950, C=1960, D=1970, E=1980, F=1990. O hasn't been reached yet , More than likley you have a D0AE-6015 which is a 1970 Automobile block, if were a D0TE-6015 it would be for a Truck block.
Old Aug 4, 2005 | 12:38 PM
atdoman's Avatar
atdoman
thanks for the reply...I'm going to clean it again real good and getting another reading...but I think I've got to be reading it wrong.
Old Aug 4, 2005 | 01:51 PM
garsten's Avatar
garsten
my guess is the first character is a D, not an oh or zero. that would make the part a 1970 casting and not the original part for a 67 year vehicle. not sure when ford quite producing the 289 and if they produced the 289 and 302 during the same years. i believe ford began producing the 302 in 1968. i would guess it's a 302 block but i know that doesn't help you much! ford increased the stroke to get from a 289 to a 302 so i don't think there is much difference between the blocks. cheers, garsten
Old Aug 5, 2005 | 09:23 AM
atdoman's Avatar
atdoman
thanks for the reply...that's what I was sort of figuring. our guess is it's probably out of a 1970 ford fairlane and it's a 302.
Old Oct 4, 2005 | 08:53 PM
ajoelane's Avatar
ajoelane
Your information here has helped me also., thanks The 351W i just purchased from a Big Bronco has a cast numer of D9AE 8015 ED24 so it is a automobile engine. thanks atleast I know now.
Old Oct 4, 2005 | 09:00 PM
Polkat's Avatar
Polkat
If it's a 302, you will find "302" cast in the lifter valley (under the intake). All 302's had this. It will be about 80 years from now before they start using "O" in the casting number, so it has to be a D, or a C with crap on it.
dentside owner
May 13, 2017 03:34 PM
rh428wf
Jul 9, 2011 06:04 PM
drew.law
Jan 23, 2011 05:23 AM
MagickNinja
Feb 23, 2010 11:30 PM
pez1
Jun 2, 2005 05:15 PM
