King pins
Old Oct 27, 2002 | 10:11 PM
Mark47025's Avatar
Mark47025
King pins
I have a 78 ford truck f150 2wd. The king pins are bad. I can only find one place that will change them for $320. My question is: is there any other trucks with the ball joint sit up that I can put in my truck and do away with the king pins? If you could do that would it be worth fooling with or should I just get the king pins fixed? Is the ball jionts a better set up than the king pins? If anyone could help I would really appreciate it. You guys have the best site anywheres!!!
Thanks alot
Mark
Old Oct 27, 2002 | 11:34 PM
Mike W's Avatar
Mike W
King pins
I can't give you a direct answer but I changed a 71 Bronco from a king pin front axle to a ball joint one. The ball joint axle was much more stable at speed. Still haven't figured out why. I don't know when the trucks went to ball joints.
Old Oct 28, 2002 | 12:05 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
King pins
It cost me $400 to have my kingpins replaced, that was after a week of trying to do it myself.
Take about STUBBURN!!!
Josh
Old Oct 28, 2002 | 06:00 AM
theonlybull's Avatar
theonlybull
King pins
the late 80's trucks have ball joints, but i dont' think the i-beams will swap in our trucks.. there's nothing wrong with the king pins, as long as you grease them often(atleast every 3000 miles) our 77 has the orginals in it, and my 79 has over 150,000 km's on the king pins i put in it... it would probably cost more then 230$ for all new ball joints too....
Old Oct 29, 2002 | 08:33 AM
macguyver's Avatar
macguyver
King pins
I just did the kingpins on my brother-in-law's '81 F-100 last weekend. He says it drives like a new truck now. He got a quote from a tire store for more than $500 but I knew that they didn't know what they were doing 'cuz they were charging him for 2 kingpin kits. Either that or they were just plain ripping him off 'cuz one kit does both sides. It's nice to work in a machine shop with access to a pin hone. Makes for a nicer fit than reaming though reaming will work if that is all that's available. IMHO Whatever you do, DON'T go with the plastic bushings. They don't hold up.
Just my $.02
'77 F-250 Camper Special 400ci
'76 F-250 Supercab 360ci
'71 Mach I 429CJ
'79 F-150 for parts
huct on foniks wurkt fer me
Old Oct 29, 2002 | 01:31 PM
oft's Avatar
oft
King pins
Truck Guy99
Jun 30, 2014 10:32 PM
DavidKelb
Mar 21, 2013 12:29 PM
MADFord4X4
22
Jul 16, 2010 12:58 AM
flcobra
16
Oct 1, 2008 09:20 PM
cheetoh
Jun 4, 2007 01:28 AM
