kenne bell
Old Aug 3, 2005 | 08:34 AM
furrby's Avatar
furrby
kenne bell
i know some of guys have the kenne bell blowers. i have a 01 f150 with the 4.6. i have true duals, short tube headers, 75mm tb, chip and a 90mm maf. i know that some of this will help when i am able to add the supercharger. what else will need and what am i looking at for price on the blower kit from kenne bell?
from what i have read. the kenne bell will be the best supercharger for my truck. is there any other supercharger i need to look at that is a twin screw?
furrby
Old Aug 3, 2005 | 01:41 PM
furrby's Avatar
furrby
just an update. don't worry about the kenne bell blower. i just called kenne bell. they have done away with a 4.6 kit. if there is a twin screw other than kenne bell. please let my know. if not, then i will be going with the prochager. thanks to all.
furrby
Old Aug 3, 2005 | 10:11 PM
FTE Herman's Avatar
FTE Herman
Whipple or Eaton?
Old Aug 4, 2005 | 03:15 PM
furrby's Avatar
furrby
i have been checking around. ford racing has one that looks like the one allen had before they shut down. the only thing i see wrong with it is that is doesn't have a intercooler. what do yall think?
furrby
Old Aug 4, 2005 | 06:03 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Getting an intercooler to work with a twinscrew supercharger is darn near impossible.
I have seen a coulple with water jackets running around the inlet manifold to cool the intake air, but even then the improvements aren't as good as an intercooler.
Old Aug 4, 2005 | 07:20 PM
stevef100s's Avatar
stevef100s
Ford Lightning's have an air to water intercooler that works great. The blower is an Eaton 112 twin screw type (roots). It has a heat exchanger under the blower, and the IC under the radiator. It works with it's own coolant tank and an electric water pump.
Old Aug 5, 2005 | 03:39 PM
furrby's Avatar
furrby
thanks. i going to check into the ford racing one a little more. thanks again.
furrby
Old Aug 28, 2005 | 10:36 PM
NewHolland's Avatar
NewHolland
Go to trixterracing.com You will be amazed at what they have done with 4.6,s..I have always thought the Bell and Whipple ones were the best too.But I am also looking at the Procharger..The intercooler will work wonders to cool the intake charge.Which will have even greater advantages in hot weather..Just a thought.Hope it helps..
Old Sep 17, 2005 | 01:05 PM
furrby's Avatar
furrby
i have vist their site. i just like the torgue curves on a twin screw. i plan to go with the procharger when i get the money.
furrby
Old Sep 18, 2005 | 09:16 AM
Blurry94's Avatar
Blurry94
The Pro Charger is an excellent kit.
Some other parts to consider before installing your blower: driveshaft loop, traction bars, and even upgrading to a good LSD like an Eaton to eliminate the "one wheel peel".
Once you install the blower, the chip will have to be sent back to be reprogramed.
Old Sep 18, 2005 | 10:28 AM
stevef100s's Avatar
stevef100s
I'm confused. I thought Procharger was a centrifugal, and not a twin screw?
Old Sep 18, 2005 | 12:48 PM
Blurry94's Avatar
Blurry94
It is a centrif, and a very nice one at that.
zamboni250
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Jun 17, 2023 10:31 AM
furrby
May 13, 2015 10:13 AM
yellowjeep76
Feb 9, 2004 12:12 PM
skipperw
Modular V10 (6.8l)
Oct 19, 2003 07:23 AM
firefox
1997 - 2003 F150
Feb 11, 2002 07:21 AM
