1978 - 1996 Big Bronco
Radiator upgrade?
Old Aug 3, 2005 | 12:09 AM
Jeter 94EB302's Avatar
Jeter 94EB302
Radiator upgrade?
I'm getting ready for a trip hauling a trailer and I'm concerned about keeping the engine cool. I read about "Super Cooling" requirements for hauling big loads and I know I'll have big hills and hot temps. I've not hauled anything heavy.
A friend at a tranny shop recommended a 3 or 4-core radiator upgrade to increase coolant volume. I assume my 94 Bronco has only 1 "core" (OEM EOTZ8005AR, "8005")? How can I know many "cores" I've got or if it's "super cooling"? I know my A/C condensor is in front of the radiator and that the radiator is a horizontal flow with tanks on each end.
I looked online and found a 1-row core for $160.95 and 2-row core for $128.95.
Anyone help and give a recommendation on upgrades? Thansk.
Old Aug 3, 2005 | 01:35 AM
aurgathor's Avatar
aurgathor
Do you have a towing package?
IMHO, an ATF cooler might be more important than a bigger radiator.
Old Aug 3, 2005 | 10:13 AM
Jeter 94EB302
No tow package. Yes, I've considered the ATF cooler as well, but aren't there two separate issues? Block vs. Transmission ... I guess the transmission is more susceptable to fail? I'll look into it, thanks for your advice.
Old Aug 3, 2005 | 11:03 AM
BillyBob69's Avatar
BillyBob69
Go with both...block and tranny. Get the cooler, but then get rid of your engine powered fan. Change out to dual electric fans. Opens more HP and pulls more air.
Old Aug 3, 2005 | 12:44 PM
aurgathor's Avatar
aurgathor
The ATF is more prone to overheating if you tow. Many people has ATF coolers, but only a few got dedicated engine oil coolers.
Old Aug 3, 2005 | 12:45 PM
Jeter 94EB302
Good call. Hadn't thought of that. I purchased a flex fan and was going to install when it arrives. Will the electric make that much difference?
Old Aug 3, 2005 | 12:47 PM
Jeter 94EB302
Thanks all. Will look into the ATF cooler. Still not sure about hte radiator and what options are available.
Old Aug 3, 2005 | 01:48 PM
BillyBob69's Avatar
BillyBob69
Yep...the electric will free up about 5 - 10 HP and they can pull more air than the factory fan or flex flan.
Old Aug 3, 2005 | 06:46 PM
deced's Avatar
deced
hey didint the dealership offer a special radiator in texas for these years named the longhorn package or texas ranger?
Old Aug 3, 2005 | 06:50 PM
deced's Avatar
deced
my bad i thought this was the 73 -79 truck fourm
Old Aug 4, 2005 | 11:12 AM
BillyBob69's Avatar
BillyBob69
I checked and it is written that electric fans will free up 17HP and an additional 20ft lbs of torque,(at the wheels), plus increase mileage. Here is the site on it...
http://www.flex-a-lite.com/auto/html/ford-truck.html
Old Aug 5, 2005 | 03:42 PM
cje07's Avatar
cje07
Why pay $300 when you can get one from the taurus's ($20-$30) that do the same exact job from a salvage yard? Sure you have to do a little leg work in regard to getting the temp probes and relays but still alot less expensive. Major cooling as opposed to the stock mechanical fans. Let me know if you need info. Be glad to pass it on to you if interested.
Old Aug 5, 2005 | 11:47 PM
kameronth's Avatar
kameronth
Flex fans are not my favorite. They pull more power then needed. I used to have a flex fan on my Bronco, and every time I would hit the gas it sounded like a jet engine. I hated it.
Old Aug 6, 2005 | 07:58 AM
Jeter 94EB302
Yeah, that can be anoying, but I'm wondering if they work (improve cooling/efficiency). I'll give it a whirl but may look at an electric down the road. Were you able to keep the fan clutch on w/the flex fan? Thanks.
Old Aug 6, 2005 | 01:16 PM
kameronth's Avatar
kameronth
No, the flex fan was a direct drive. They guy that had the Bronco before me put it on because he was in a front end crash.
tacurl03
Feb 27, 2017 09:48 PM
bigTEE56
Jan 1, 2017 03:31 PM
Ford_Six
Oct 18, 2012 07:49 PM
michaelshewkin
Jul 21, 2010 10:23 AM
7.3 Ex
Aug 5, 2007 01:32 AM
