1978 - 1996 Big Bronco
5.0L check engine light
Old Aug 2, 2005 | 10:15 AM
Augist's Avatar
Augist
96 Bronco runs like a dream but the check engine light comes on after 1 mile--exactly--when I run the AC. I get an air flow/egr @ ~60% throttle error code every time. Replaced the egr (twice-got a bad one from NAPA), O2 sensor, coolant sensor, air & fuel filter, plugs, wires, cap, tested vacuum lines-good, replaced brittle lines anyway. It does not idle down under AC load. Where do I go next?
Old Aug 2, 2005 | 10:47 AM
MBBFord's Avatar
MBBFord
I hate those stupid check engine lights, They come on an off for almost nothing, it could be cause your gas cap isn't tighted down anough, or your catalitic converter is a little cologged, After a while, if you don't change anything it will just quit coming on, and then a while latter it might come back on again.
For the trottle error code I don't know what you could do, cause it looks like you replaced everything exept for the computer.
Good luck,
Matt
Old Aug 2, 2005 | 11:10 AM
Kemicalburns's Avatar
Kemicalburns
have you replaced the egr sensor? how about the TPS or IAC?
Old Aug 2, 2005 | 12:01 PM
Augist's Avatar
Augist
The egr sensor was replaced. The TPS or IAC have their own fault codes. Have you heard of engine vac?
Old Aug 2, 2005 | 12:08 PM
Kemicalburns
is this a 302 engine? if so the egr tube comes out of the lower intake correct. its possible that some carbon has built up inside the manifold. you might run a can of seafoam thru the brake booster vac line and some thru your gas tank as well. then see if it clears up at all.
96halfton
Nov 6, 2016 04:31 PM
cat375l
1983 - 2012 Ranger & B-Series
Jul 24, 2015 05:40 PM
delano79
Aug 30, 2011 08:36 PM
techsuphunt
Escape & Escape Hybrid
May 1, 2008 10:28 PM
caperail
General Automotive Discussion
May 13, 2005 10:28 AM
