04 Expy question - low tire warning light?
Old Aug 2, 2005 | 08:14 AM
blakrj's Avatar
blakrj
Being all new to this, I was reading through the user manual (quiet night!). I do not believe that my car has the "Tire Pressure System" fitted (although I'm not sure how to find out if it does). However, the manual mentions the "Low Tire Warning" lamp without mentioning "if equipped". When I turn the ignition on, I do not see this lamp light up.
The manual says "If this light fails to illuminate when ignition is turned to ON, continues to flash or remains on, have the system serviced immediately." Am I correct in assuming I need to get it to the dealer ASAP?
2004 Expedition Eddie Bauer 4x2 2v 4.6L
Old Aug 2, 2005 | 01:50 PM
High_Horse's Avatar
High_Horse
Just take your VIN # and go to Ford and have them tell you the options on your vehicle. It may also be listed on the inside of your drivers side door with a code.
Old Aug 2, 2005 | 07:21 PM
Lee E Quicksall's Avatar
Lee E Quicksall
i think i can only help you with the question of," do i have tire pressure system." go look at your valve stems, if they are silver in color, it is my understanding that indicates the tire pressure monitoring system. hope this helps.
later,
lee
Old Aug 2, 2005 | 08:46 PM
Sanchez_315er's Avatar
Sanchez_315er
When you first start the truck, you will see all of the gauges light up... one will have a picture of a tire gonig flat.... lemme see if I can find a pic....
There ya go... right from the owner's manual.
Old Aug 3, 2005 | 11:21 PM
blakrj's Avatar
blakrj
Therein lies my problem - no light comes on. The manual says it should, but says nothing about only if you have the Tire Pressure System installed. I guess I'll swing it by the dealer on the weekend for them to take a look.
pbruckne
6.7L Power Stroke Diesel
17
Jan 5, 2020 07:45 AM
Aune163rd
Modular V10 (6.8l)
Jun 2, 2012 03:28 AM
Rickx
Oct 12, 2011 06:43 PM
Marauder92V
21
Jun 11, 2011 09:06 PM
glsurratt
Dec 1, 2010 07:39 PM
