I have a 73 f-250 with a 390 pretty much stock exept rv cam and holly 650 dp.
the engin has about 10,000 miles on it every thing redone.
every time I pull my my boat up a real steep grade it will do fine up to a point then will start missing and will have to slow down alot and downshift. At first thought it might be jetting, had 62 in primary and 72 in secondary. Changed primarys to 65 no diffrence so bumped them up to 68 still no change. Any help out their????
...Welcome frnk73f250, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Rule out vapor lock by checking the accelerator pump at the exact time this happens. If there is "air" coming out the shooters when you pump the throttle (or a mix of "air" and gas), you are vapor locked.
If that's not it, you just aren't getting enough fuel to carry the load for a long enough period of time.
Check filters, change pump, check strainer in tank (in order of increasing difficulty)...
Or, do the filter(s) before you try the trip again, and then check for vapor lock, and then if it's not fixed, change the pump and check the strainer in the tank.
Actually, that was kinda stupid, that doesn't rule out anything. Ignore that paragraph
The miss could be related to a bad spark plug or bad spark plug wire.
