360/390 heads swapable?
Old Aug 10, 2005 | 09:42 AM
Mike G's Avatar
Mike G
Originally Posted by dmoore0733
how do you tell the difference between 2 barrel and 4 barrel heads, just by looking that is?
No difference between 2v or 4v. That was primarily an issue with the 351c motors...
Originally Posted by Fomoko1
Years back I overhauled what I think was a 360 2 bbl from a 68 Ford Ranger(very sweet truck, wish I had it now). What I seem to remember is that the pistons were stamped 390 4V. Maybe my memory is toast but I am fairly certain that the motor was a 360. Is this possible or not?
The "390 4v" pistons would be the units from a car, with higher compression than the truck, same as the 360 piston as far as compression height.
--Mike
Old Aug 10, 2005 | 12:32 PM
1975Ford's Avatar
1975Ford
Some 4v FE engines did have a slightly bigger valves on the cylinder head.
Old Aug 10, 2005 | 12:35 PM
ford390gashog's Avatar
ford390gashog
go to the fe forum and you will find all the answers and then some.
Old Aug 10, 2005 | 04:10 PM
Mike G's Avatar
Mike G
Well what about the 6v and 8v FE heads??? The 428cj and the 427 heads had bigger valves.
--Mike
Old Aug 10, 2005 | 04:47 PM
1975Ford's Avatar
1975Ford
I bought a book at a book store which shows the casting numbers for the heads and what size of valves they came with and in what model of fords with cross references to intake size (2v or 4v). Some cylinder heads with 4 barrel intakes show bigger valves. The only true way to determine the valve size is to cross reference the casting number off the heads or measure the valve itself.
Yes, the 427 and 428 heads did come out with bigger valves. The police interceptor engines had bigger valves.
Old Aug 11, 2005 | 09:00 PM
dmoore0733's Avatar
dmoore0733
o.k, i think i will just stick with 360/390 2V heads and the intake and carb i already have. i looked in the classified ads and found nothing. my heads have broken castings on the exaust side so i have to replace them. if anyone out there has an affordable/rebuildable set, let me know.
thanks,
derek
Old Aug 12, 2005 | 10:04 AM
Mike G's Avatar
Mike G
Check with your local salvage yard or auto parts store. You can grab a set from the salvage yard for about $40, then have them rebuilt. Or drop into Autozone or the such and buy a complete head ready to go for around $160 each. These are generally the D2T castings and ready for bolt and go.
--Mike
Old Aug 18, 2005 | 05:25 AM
dmoore0733's Avatar
dmoore0733
man, i checked a local yard yest. and they wanted 250 for a set!, ill just keep checking iwanna mag. and find a core motor for 100 or 150.
Old Dec 19, 2005 | 04:31 PM
bloodhound51's Avatar
bloodhound51
yes 360 and 390 heads are interchangable and they are fairly decent heads most all fe heads will interchange some are cobra jet which are rare but very sweet. make sure to look at the mating surfaces where the manifold touches the head and the intake touches also where the head touches the block if it is pitted you'll need to have them re machined, these heads are notorious for exhaust manifold leakage.
Fellenz
23
Dec 8, 2014 04:51 PM
raven3
Feb 6, 2014 04:29 PM
1956in1956
Sep 14, 2013 11:51 AM
teason72
15
May 1, 2012 08:05 AM
Curtis360
Mar 30, 2002 12:53 PM
