Sponsored by: Auxito
Problem with keyless entry
Old Aug 1, 2005 | 01:46 PM
brettds's Avatar
brettds
Question Problem with keyless entry
I have a 1999 F150 and am having a problem with the keyless entry remote. It used to work at long distance and now I have to be standing right next to the truck for it to work. Before you all laugh, I have changed the battery. I've got two remotes and both are doing the same thing. I called my Ford dealer and they told me that didn't sound right and that the module either works of doesn't.
I have a few questions:
1) Has anyone else had this problem and what was the solution?
2) Where is the sensor/module located? I've been told anything from behind the dash to in the door.
3) If anyone has a pic, would you please post?
Thanks in advance.
Old Aug 1, 2005 | 01:53 PM
lancekilgore's Avatar
lancekilgore
Are you sure you just did not get bad batteries, or try to re inialize the remotes with the key switch. couldn't hurt. But know I have no idea whete the switch is.
I have had this happen to me on other vehiciles and it turned out to be a bad remote. thats why I reccommended to re iunialiized the remotes.
Lance
Old Aug 1, 2005 | 02:12 PM
brettds's Avatar
brettds
I haven't tried re-initializing becuase it happens on both remotes. I'll try that, though.
Old Aug 1, 2005 | 03:41 PM
PaulC's Avatar
PaulC
What condition is the truck's battery in?
Old Aug 2, 2005 | 09:08 AM
brettds's Avatar
brettds
Battery's about 2 years old and in good shape. This started about 1.5 years ago.
Old Aug 3, 2005 | 07:58 PM
Big-Red-Lariat's Avatar
Big-Red-Lariat
if you touch the remote to your chin before pressing the buttons, it will work from a much greater distance....sounds crazy but it uses your body as a transmitting antenna. Try it.
Old Aug 4, 2005 | 09:52 AM
chaser1602's Avatar
chaser1602
Lance
Is reinitailizing when you turn the ign. switch on off 8 times and then press the key pad?
I wish I could have come up with Big Red's idea.Thats funny
Old Aug 9, 2005 | 07:33 PM
Big-Red-Lariat
Don't laugh....try the chin thing, it works from way across the parking lot. (make sure no one is watching you first)
I read it here on FTE !
Edds
1978 - 1996 Big Bronco
Mar 15, 2016 08:28 PM
2002exPSD
Feb 13, 2016 10:35 AM
twigsV10
13
Sep 28, 2015 10:33 AM
SolarKing
Jan 12, 2015 05:23 PM
pharbach
1997 - 2003 F150
Nov 23, 2004 04:08 PM
