Bronco II Ford Bronco II
compressor clutch switch fault
Old Jul 31, 2005 | 12:18 PM
aleahey's Avatar
aleahey
my a/c on my b2 has never worked, bought this puppy last year. its getting pretty unbearable so i pulled codes and got 67 KOEO. reads a/c compressor clutch switch fault.
any idea what that is and how one can fix it?
Old Jul 31, 2005 | 04:15 PM
Ken00's Avatar
Ken00
That code can also be the neutral switch, did you have it in neutral when you pulled the codes?
Drop me an email if you want the pinpoint test for code 67.
Old Jul 31, 2005 | 05:20 PM
aleahey's Avatar
aleahey
no sir, was in gear, koeo.
Old Jul 31, 2005 | 09:15 PM
mgerdes's Avatar
mgerdes
check the shrader valve, push it down to check for any pressure in the system, its next to the drier, the round black thing with a/c hoses coming out of it on the pass side of the engine. if little or no pressure pull the two wire connector off the low pressure switch right next to the drier. jump those two wires together and turn your a/c on. your compressor should run. if it runs without to much noise you might consider a leak check, and then a good shot of 134a.
i did that with my 88 bII thats been sitting since 95 and so far its working great.
Old Aug 1, 2005 | 09:26 AM
Monty06's Avatar
Monty06
just one question what does fuel pressure have to do with ac compressor clutch failure
Old Aug 1, 2005 | 08:23 PM
Ken00's Avatar
Ken00
The code 67 can also mean a neutral switch probem and you have to have it in nuetral on a manual when you pull the codes. Try pulling the codes again, I have the proper procedure in the tech info thread at the top of the forum, pulling eec-iv codes.
If the code doesn't come back try checking the charge in the AC system.
Old Aug 1, 2005 | 08:24 PM
Ken00's Avatar
Ken00
Whos talking fuel pressure???? jk
rla337
Aug 9, 2013 12:54 PM
sonora pass
1983 - 2012 Ranger & B-Series
Feb 19, 2009 01:09 PM
FitchBanjos
Feb 26, 2008 10:56 AM
IronMiner
1997 - 2003 F150
Feb 18, 2007 12:54 PM
jrickc
Jun 4, 2005 04:01 PM
