Yes, but a code reader is recommended for several reasons.
1: it is easier to use, and foolproof.
2: it beeps, so the codes are now audible
3: you cannot perform a wiggle test without one (just in case you ever had an intermittent sensor)
4: it is difficult to perform a cylinder balance test without a code reader.
I have a code reader, and wouldn't go back to the jumper method (EVER). It just plugs in, and has a switch on it to activate it.
Hi Khantyranitar,
Whioch code reader is best for OBD-1?
Thank you,
Fordboy49
Khantyranitar is right, an actual OBD-1 reader simplifies things compared to jumping, I have both an OBD-1 and OBD-II reader and they have saved me tons of money on Diagnostics. As for brand, it does not really matter, they all work fine.
I have an actron brand, but most of them should work fine. I recommend the Atron on this one, because the manual is very complete, the price is right, an it has the audio beep feature.
Disregard checking the modulator. I climbed under the van Saturday and couldn't find it. I went to the parts store and had him pull one so I knew what it looked like. I climbed back under the van and I can now say that my van doesn't have a modulator. The transmission mechanic stated that only half of the 95's had modulators so mine must be a later 95. I will check to see if I have back pressure in the fill tube. Thanks for your help.
