I have a 1992 Areostar 4 litre. It has started to idle rough. I have tested the fuel pressure it was ok, change the fuel filter and still the same problem. Any ideas out there.
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
I would try cleaning your IAB. If that does not work, replace, common Ford issue. Also it is probably overdue for a decaboning. (do a search for seafoam.)
Plugs and wires should be replaced at least every 25-30k miles, unless you have double life type plugs (60K), but the wires should still be replaced often. You will notice that under most circumstances, the plugs will outlast the wires.
I would agree with most of the aforementioned suggestions. I would also add a possible vacuum line problem to the list - especially if the problem suddenly started. Remove the rear engine cover from within the passenger compartment and check the vacuum "tree" near the top, left, rear side of the engine. There should be 4 or 5 vacuum hoses of various sizes attached to the "tree". There will also be 1 or 2 unused ports but these should have a small cap in place. Engine back pressure sometimes dislodges the lines or caps. A quick, inexpensive fix if this is the case.
I agree with the vacuum line theory too. Check all the vacuum hoses, and make sure they are still flexible. I had forgotten, but recently, I had to replace the vacuum lines in our Aerostar, and rough idle was one of the symptoms.
Will a hole or two in the muffler cause rough idleing? My 94 has skipped for a while now but I figured it was a back pressure problem due to the holes. I was going to replace the muffler this weekend to see if that would help. From reading a few post this morning it appears I might have other issues as well. I might need to suck-it-up and go get an engine analyzer performed.
No, but you could wrap muffler tape around it and cover the hole until you want to replace it.
Go with the tips already suggested. It could also be an injector. Read the plugs when you change them.
Yeah, if its running rough, there is a pretty good chance there is at least one code. Do a cylinder balance test too (If you have an OBD-I eg EEC-IV). That can find any missfire/injector issues. What that does, is the computer shuts off injectors one at a time, and measures the difference in performance. If it does not degrade by the expected amount, it means that that cylinder was already haveing problems.
Let me clarify the running rough. I called around yesterday and stopped by a garage and the one thing they all asked was if my "check engine" light was on. NO it is not. Strange! The van runs smooth at 55-60 mph but skips real bad at 70 and also if I accelerate up a hill. I've had problems with vacuum lines blowing off of the vacuum tree and I don't know if I reattached them all. I need to find the vacuum diagram and see if I can verify that they are all connected. I found a shop that will hook the van up to an analyser for $40 so I am going to try and get it in there. Thanks for all of your comments. Please keep them coming. I need to get this fixed because it is sucking gas like crazy. Which makes me wonder if I'm getting too much gas. I say that because I can floor it, the van downshifts, and runs okay. Just another thought.......
Vacuum lines should never blow off. Replace the PVC valve if they do. Also, replace the vacuum lines, and if nessecary, clamp them on. Also, if they blow off, check the transmission modulator.
The van will not get too much gas unless there is another issue that like a faulty O2 sensor, or a faulty MAF sensor. Also, check for fouled plugs. I'm thinking you have a vacuum leak, and thjat is the cause of the rough running.
Your vehicle is an OBD-I, so go to your local auto parts store and get a code reader for OBD-I fords. Should run about $30, which is a lot cheaper than paying a mechanic to read them for you. Follow the directions and see what the computer can tell you.
Are you experiencing "blowby"? Do you feel air pressure at the oil fill tube?
It means you have a bad PCV valve or maybe bad rings. It could explain why lines are blowing off.
